I will try to answer your questions. 1/ Where are those library names coming from ? How are they generated? One of the original objectives for edm was to build a display manager to which other, perhaps remotely located, developers could contribute. The biggest potential problem was avoiding namespace collisions. Suppose you and I both wish to build a text display widget that may be used by other sites. If I build a widget, I must pick two global symbols. For example, for a text display widget I could choose the following: create_textDisplayWidgetPtr clone_textDisplayWidgetPtr The widget then gets packaged into a shareable library named, for example, libTextDisplayWidgetLibrary.so. These names are descriptive but might be vulnerable to colliding with names associated with the widget you build. As a result, I suggested using uuid-derived names. I pick my names by issuing the uuidgen command, which gives something like 5c2fdd15-0dcf-4ead-b0e4-cdbe653e5637 Now, instead of the above symbols, I use create_5c2fdd15_0dcf_4ead_b0e4_cdbe653e5637Ptr clone_5c2fdd15_0dcf_4ead_b0e4_cdbe653e5637Ptr and I name the library lib5c2fdd15-0dcf-4ead-b0e4-cdbe653e5637.so These names are certain to be globally unique. ------------- The way you use the above widget library is as follows: To examine contents: edm -show [full path to library]/lib5c2fdd15-0dcf-4ead-b0e4-cdbe653e5637.so To add widgets to the edm objects file: edm -add [full path to library]/lib5c2fdd15-0dcf-4ead-b0e4-cdbe653e5637.so ----------------------------------------------------------------------------------- 2/ Where did I go wrong in the GIF widget configuration ? I did something very similar for the PNG widgets and it worked immediately (kudos!). There might have been a problem with the gif c++ file (A fix was released in version 1-11-0t on 6-Mar-2007 that was related to the gif object global names). -----------------------------------------------------------------------------------
No one is being asked to use edm. If medm does all you want, why switch to edm? medm is a fine piece of work. In our case, we were using a non-epics commercial product from Vista Control Systems. After switching to EPICS, we wanted a few additional medm features that were present in the Vista display manager. I spoke with Ken Evans about this and was left with two distinct impressions: 1) It was somewhat difficult to add new features to medm 2) My request had a very low probability of being implemented This inspired me to take a shot at writing an extensible display manager. I spent the next six weeks, at home, in the evenings and on weekends, developing edm. Over the years, edm has evolved considerably as a result of many excellent comments, criticisms, and contributions from various EPICS developers and users. ----------------------------------------------------------------------------------- 4/ Is someone maintaining a library of edm widgets? The SNS-hosted edm distribution includes widgets from various sources. ----------------------------------------------------------------------------------- 5/ Is there any other display manager worth the try? Some sites still use DM2K or edd/dm. The new java-based tools are on the horizon and soon edm itself will be obsolete. ----------------------------------------------------------------------------------- 6/ Why does (almost) none of the epics software work out of the box? Keep that one for later, that another $64K question Community-based software suites like EPICS unfortunately require some degree of user participation. We just can't keep up with new platforms, new os/library distributions, new include file organizations, new compiler behavior/constraints, new make quirks, etc. Most EPICS developers have full-time jobs doing things unrelated to EPICS development. ----------------------------------------------------------------------------------- John Sinclair Emmanuel Mayssat wrote: On Tue, 2007-04-10 at 18:27 -0700, Emmanuel Mayssat wrote: Attachment:
smime.p7s
ANJ, 10 Nov 2011 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
