Emmanuel,
Using a Scion Framegrabber I developed some what of a hybrid. The
framegrabber runs on linux, with of course a linux driver, but it is
"controlled" by EPICS. Basically a C app monitors pvs that tell it to
grab a frame. The beam profile data is then written to pvs for the
operator to view through a MEDM screen and the images can be viewed with
any application.
Wesley
Pearson, MR (Matthew) wrote:
We've been using, as well as the Flea cameras, the AVT (Allied Vision
Tech) Oscar Firewire cameras, which are high resolution and have colour
versions. We've only run this in Windows though, using the CMU driver.
Would be interesting to see if this works in Linux with Coriander...
We've also tested the JAI TMC-1405 Gigabit Ethernet camera, which is a
1.4Mpixel colour camera with an ethernet connection (no encoding or
compression though) - this isn't as sensitive as the Flea cameras. This
doesn't have a web server, and needs windows software to view the video.
There are software projects out there which can capture IP video, but
not sure what Linux support exists.
Axis now produce a high resolution network camera (the 223M). This might
be a good solution for diagnostics. But it's probably not as sensitive,
or have the same bandwidth, as cameras such as the Fleas or AVTs etc.
Probably not suitable for low light diagnostics. But this is like all
the other Axis cameras, with built in web server, compression, encoding,
etc.
Cheers,
Matthew
Diamond Light Source
-----Original Message-----
Sent: 05 April 2007 19:05
To: EPICS Tech-Talk
Cc: [email protected]
Subject: Frame grabber
Hello,
I am using EPICS on a linux IOC.
I am interested in doing some video acquisition.
I was wondering if anybody has already developed a video epics driver.
If so, what is the hardware/software combination you recommend?
I am looking at all possible solutions, i.e. snapshot mode or 30Hz+ real
time acquisition.
Alternatively, I may be interested in all in-one-device (camera for
acquisition + web server and Ethernet connection device)
At this point anything goes ;-)
Emmanuel
begin:vcard
fn:Wesley Moore
n:Moore;Wesley
org:Thomas Jefferson National Accelcerator Facility;Free Electron Laser
adr:Suite #19;;12000 Jefferson Avenue;Newport News;VA;23606;USA
email;internet:[email protected]
title:Computer Scientist
tel;work:(757) 269-6033
tel;fax:(757) 269-6384
tel;pager:(757) 584-6033
url:http://www.jlab.org/FEL/
version:2.1
end:vcard
- Frame grabber Emmanuel Mayssat
- RE: Frame grabber Pearson, MR (Matthew)
Building and crashing EDM Emmanuel Mayssat
<2007>
RE: Frame grabber and image analysis Emmanuel Mayssat
<2007>
ANJ, 10 Nov 2011 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
