ʦê»Àñ wrote:
> thanks S Kate.Feng that RTEMS has been built successfully with RTEMS-mvme5500
> BSP she provided. but an error appears now while compiling EPICS3.14.6. the
> log is listed as follows:
I sent you the configure files for 3.14.6. I hope it works fine.
Kate
> make -C libCom install
> make[2]: Entering directory `/home/rtems/base-3.14.6/base/src/libCom'
> make -C O.linux-x86 -f ../Makefile TOP=../../.. T_A=linux-x86 install
> make[3]: Entering directory `/home/rtems/base-3.14.6/base/src/libCom/O.linux-
> x86'
> make[3]: Nothing to be done for `install'.
> make[3]: Leaving directory `/home/rtems/base-3.14.6/base/src/libCom/O.linux-
> x86'
> make -C O.RTEMS-mvme5500 -f ../Makefile TOP=../../.. T_A=RTEMS-mvme5500
> install
> `/home/rtems/base-3.14.6/base/src/libCom/O.RTEMS-mvme5500'
> /opt/rtems1/bin/ppc-rtems-gcc --pipe -B/opt/rtems1/ppc-rtems/mvme5500/lib/
> -specs bsp_specs -qrtems -fasm -c -mcpu=7450 -Dmpc7455 -mmultiple -
> mstring
> -mstrict-align -DHAS_IOOPS_H -DOSITHREAD_USE_DEFAULT_STACK
> -ansi -g -O3 -Wall -I. -I.. -I../../../src/libCom/bucketLib
> -I../../../src/libCom/ring -I../../../src/libCom/calc
> -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd
> -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf
> -I../../../src/libCom/ellLib -I../../../src/libCom/env
> -I../../../src/libCom/error -I../../../src/libCom/fdmgr
> -I../../../src/libCom/freeList -I../../../src/libCom/gpHash
> -I../../../src/libCom/logClient -I../../../src/libCom/macLib
> -I../../../src/libCom/misc -I../../../src/libCom/osi
> -I../../../src/libCom/taskwd -I../../../src/libCom/timer
> -I../../../src/libCom/tsDefs -I../../../include/os/RTEMS -I../../../include
> -I//include ../../../src/libCom/bucketLib/bucketLib.c
> as: unrecognized option `-mppc'
> ../../../src/libCom/bucketLib/bucketLib.c:20:19: stdio.h: No such file or
> directory
> ../../../src/libCom/bucketLib/bucketLib.c:21:20: stdlib.h: No such file or
> directory
> ../../../src/libCom/bucketLib/bucketLib.c:22:20: string.h: No such file or
> directory
> In file included from /usr/local/rtems/rtems4.6.0/lib/gcc-lib/powerpc-
> rtems/3.2.3/include/syslimits.h:7,
> rtems/3.2.3/include/limits.h:11,
> from ../../../src/libCom/bucketLib/bucketLib.c:23:
> rtems/3.2.3/include/limits.h:132:75: no include path in which to find
> limits.h
> ../../../src/libCom/bucketLib/bucketLib.c:24:18: math.h: No such file or
> directory
> ../../../src/libCom/bucketLib/bucketLib.c:25:18: time.h: No such file or
> directory
> ../../../src/libCom/bucketLib/bucketLib.c: In function `bucketStringCompare':
> ../../../src/libCom/bucketLib/bucketLib.c:222: warning: implicit declaration
> of function `strcmp'
> ../../../src/libCom/bucketLib/bucketLib.c: In function `bucketCreate':
> ../../../src/libCom/bucketLib/bucketLib.c:320: warning: implicit declaration
> of function `fprintf'
> ../../../src/libCom/bucketLib/bucketLib.c:320: `stderr' undeclared (first use
> in this function)
> ../../../src/libCom/bucketLib/bucketLib.c:320: (Each undeclared identifier is
> reported only once
> ../../../src/libCom/bucketLib/bucketLib.c:320: for each function it appears
> in.)
> ../../../src/libCom/bucketLib/bucketLib.c:355: warning: implicit declaration
> of function `calloc'
> ../../../src/libCom/bucketLib/bucketLib.c:367: warning: implicit declaration
> of function `free'
> ../../../src/libCom/bucketLib/bucketLib.c: In function `bucketShow':
> ../../../src/libCom/bucketLib/bucketLib.c:580: warning: implicit declaration
> of function `printf'
> ../../../src/libCom/bucketLib/bucketLib.c:604: warning: implicit declaration
> of function `sqrt'
> make[3]: *** [bucketLib.o] Error 2
> make[2]: *** [install.RTEMS-mvme5500] Error 2
> make[2]: Leaving directory `/home/rtems/base-3.14.6/base/src/libCom'
> make[1]: *** [libCom.install] Error 2
> make[1]: Leaving directory `/home/rtems/base-3.14.6/base/src'
> make: *** [src.install] Error 2
> I want to know where it find these .h files? I really did not find these .h
> files in the epics base directory and its subdirectories. I will attach the
> complete log to you.
> From the log, I see that error appears while compiling the file
> base/src/libCom/bucketLib/bucketLib.c, and it says that can't find stdio.h,
> stdlib.h, and so on, and there doesn't exist these .h files in the base
> directory and its subdirectories. only epicsStdio.h,epicsString.h and some
> other .h files exist in base/include.
> I also see while compiling the file ase/src/libCom/osi/os/posix/osdProcess.c,
> in the file, there are '#include <stdio.h>, #include <stdlib.h>,
> #include <string.h>', and no error appears. I wonder how these .h files are
> found?
> besides, when compiling the file bucketLib.c, there is the parameter
> -I../../../include/os/Linux -I../../../include, and when compiling the file
> osdProcess.c, there si the parameter -I../../../include/os/RTEMS
> -I../../../include, so in theory, buchetLib.c should be able to be compiled.
> but now...
> last, I see in the log: '/usr/local/rtems/rtems4.6.0/lib/gcc-lib/powerpc-
> rtems/3.2.3/include/limits.h:14:25:no include path in which to find
> limits.h', why it will find limits.h in the directory(I build the cross-
> compiler tools in the directroy /usr/local/rtems/rtems4.6.0)
> best regards
> Haoli Shi
> errorcompile070409 Type: Plain Text (text/plain)
> Encoding: base64
- Re: epics compiling problem ʦê»Àñ
- epics compiling problem 师昊礼
Re: firewire video on RTEMS-4.6.x-MVME5500 Kate Feng
<2007>
<2007>
