1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Outputting a constant value
To: David Dudley <[email protected]>
Cc: [email protected]
Date: Wed, 04 Apr 2007 09:13:35 -0500
David Dudley wrote:
I have a BO where every time I trigger it, I want to output a constant
value.  Since the .VAL field can't be set to a constant through vdct, is
there an easy way to force it to have a '1' value all the time?
Set the DOL field to the value you want, and the OMSL field to "closed_loop".
But I'm surprised that you can't set the VAL field using vdct.  I can,
with EPICS 3.14.8.2.  (I think vdct will let you set a field if
the .dbd file specifies a promptgroup for the field.  I'm using vdct 2.5,
build 1271, by the way.)
Tim Mooney ([email protected]) (630)252-5417
Beamline Controls & Data Acquisition Group
Advanced Photon Source, Argonne National Lab.
Outputting a constant value David Dudley
Prev: Outputting a constant value David Dudley
Next: RE: Outputting a constant value Paul Sichta
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 10 Nov 2011 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
