Timo,
Please send the output from the following command for all three of the
symbols that are undefined:
c++filtppc _Z7WireSetIsEvRKT.
This "demangles" the c++ symbol. Hopefully, we can determine which of the
overloaded functions are undefined.
A complete rebuild of base, and the application, might also help. Also, make
certain that the same c++ compiler version is used to produce all of the
object code linked into mv3100.munch.
Jeff
> -----Original Message-----
> From: Korhonen Timo [mailto:[email protected]]
> Sent: Thursday, March 29, 2007 7:12 AM
> To: '[email protected] '; 'Williams Jr, Ernest L.'
> Subject: WireSet & mpc8540
> Hello all,
> I have been trying to get EPICS running on a Motorola mv3100 and vxWorks
> 6.2,
> using the newest EPICS release (3.14.9). The build goes smoothly and
> without complaints.
> However, when I build the application and load it, I get a few
> unresolved symbols:
> ld < mv3100.munch
> Warning: module 0x1a16f20 holds reference to undefined symbol
> _Z7WireSetIfEvRKT.
> _Z7WireSetIiEvRKT.
> _Z7WireSetIsEvRKT.
> ld(): error loading file (errno = 0xe0005).
> value = 0 = 0x0
> Trying to trace these back, they seem to come from Channel Access. The
> prototypes
> (WireSet, I believe) are declared in osiWireFormat.h, and the
> implementation, as far
> as I have understood it correctly, are in osdWireFormat.h. I could not
> sort out the ifdefs to
> see why this routine is not linked in, or what the problem actually is.
> I ran out of ideas. Can somebody help me further?
> Timo
> Timo Korhonen PSI (Paul Scherrer Institut, http://www.psi.ch)
> CH-5232 Villigen PSI
> tel + 41- 56 3103262 fax + 41 - 56 310 3383
> e-mail: [email protected]
- WireSet & mpc8540 Korhonen Timo
Question about mbboDirect record Mark Rivers
NSLS Controls Computing Leader Position Zitvogel, Emil
<2007>
Re: WireSet & mpc8540 Ernest L. Williams Jr.
<2007>
