On Thu, 2007-03-29 at 15:12 +0200, Korhonen Timo wrote:
> Hello all,
> I have been trying to get EPICS running on a Motorola mv3100 and vxWorks
> 6.2,
> using the newest EPICS release (3.14.9). The build goes smoothly and
> without complaints.
> However, when I build the application and load it, I get a few
> unresolved symbols:
> ld < mv3100.munch
> Warning: module 0x1a16f20 holds reference to undefined symbol
> _Z7WireSetIfEvRKT.
> _Z7WireSetIiEvRKT.
> _Z7WireSetIsEvRKT.
> ld(): error loading file (errno = 0xe0005).
> value = 0 = 0x0
What object file is referencing this in your App?
I don't see this on my mv3100 application:
> Trying to trace these back, they seem to come from Channel Access. The
> prototypes
> (WireSet, I believe) are declared in osiWireFormat.h, and the
> implementation, as far
> as I have understood it correctly, are in osdWireFormat.h. I could not
> sort out the ifdefs to
> see why this routine is not linked in, or what the problem actually is.
WireSet is new in R3.14.9.
> I ran out of ideas. Can somebody help me further?
Make sure that you build iocCoreLibrary in EPICS BASE.
Make sure that you have the following in your Makefile:
xxx_LIBS += $(EPICS_BASE_IOC_LIBS)
xxx_OBJS_vxWorks += $(EPICS_BASE_BIN)/iocCoreLibrary
-- Ernest
> Timo
- WireSet & mpc8540 Korhonen Timo
RE: ASYN Octet driver question David Dudley
Proposed change in asyn interruptCallback APIs Mark Rivers
<2007>
RE: WireSet & mpc8540 Jeff Hill
<2007>
