I have been trying to get EPICS running on a Motorola mv3100 and vxWorks 6.2, using the newest EPICS release (3.14.9). The build goes smoothly and without complaints. However, when I build the application and load it, I get a few unresolved symbols: ld < mv3100.munch Warning: module 0x1a16f20 holds reference to undefined symbol _Z7WireSetIfEvRKT. Warning: module 0x1a16f20 holds reference to undefined symbol _Z7WireSetIiEvRKT. Warning: module 0x1a16f20 holds reference to undefined symbol _Z7WireSetIsEvRKT. ld(): error loading file (errno = 0xe0005). value = 0 = 0x0 Trying to trace these back, they seem to come from Channel Access. The prototypes (WireSet, I believe) are declared in osiWireFormat.h, and the implementation, as far as I have understood it correctly, are in osdWireFormat.h. I could not sort out the ifdefs to see why this routine is not linked in, or what the problem actually is. I ran out of ideas. Can somebody help me further? Timo -- Timo Korhonen PSI (Paul Scherrer Institut, http://www.psi.ch) CH-5232 Villigen PSI tel + 41- 56 3103262 fax + 41 - 56 310 3383 e-mail: [email protected]
ANJ, 10 Nov 2011 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
