> From: Korhonen Timo [mailto:[email protected]]
> Denison, PN (Peter) wrote:
> > I was searching for drvTS yesterday, and couldn't find it for
versions
> > of base after 3.14.8
> > I know that it was removed from base, and I found this section of
the
> > release notes: "These are removed from EPICS base. The version that
> > previously came with base was the version that worked with the APS
> > event system. It is available from APS. The version that works with
> > the newer event systems that evolved from the APS system is
available
> > from the Swiss Light Source."
> > As we are using the "newer event systems", I guess we'll need the
SLS
> > version. Can anyone help me get hold of it - Timo?
> If you _really_ want it, we can give you 'our' version of
> drvTS. However, if you are using 3.14., I would recommend
> moving to GeneralTime. We have a GeneralTime time driver for
> the MicroResearch EVR/EVG( although it may need some minor
> modifications for the 200-series EVRs.). We have no
> intentions to support drvTS further. GeneralTime is a big
> improvement over drvTS.
I was planning to move to generalTime eventually, and I'm pleased to
hear that it's ready to try.
> > I assume that this is orthogonal to generalTime, and I'll still need
a
> > version of drvTS to support the MicroResearch EVR, even if I were to
> > get hold of generalTime (which I have managed to find a link for)?
We
> > have the drivers for the EVR, but they don't compile against
> > base-3.14.8 because drvTS is missing.
> I would like to state it once again:
> the drvTS will not be supported anymore and will be replaced
> by General Time.
> (as discussed in the last EPICS meeting. It took us a while to
> implement the replacement but at least a first version exists
> since a few months.)
> There are still a few issues to be sorted out, but we have tested the
> GeneralTime (event) driver extensively.
> We have sent our GeneralTime package (GT base + our eventTime
> driver) to Andrew and a few other people for them to take a look
> at it and to do the necessary preparations for integrating it.
> We can of course send you the same package, and try to help you
> to get started. There will also be a talk in the Epics meeting in
> Hamburg (by Babak) and Babak will be there for detail discussions.
I've got hold of the 1-2-0 release from a link recently posted to
tech-talk by David.
By "our eventTime driver", do you mean the MicroResearch EVR driver, or
another intermediate driver that is also required?
> I do not immediately remember what the dependency between the EVR
> drivers and drvTS is, but Babak could probably tell it right away.
> Let us take a look at it (however, this week there is a SLS shutdown
> and people are pretty busy with maintenance and testing new stuff.)
I've done a bit more digging and now understand a little more. The only
dependency seemed to be on TSepochUnixToEpics(), which I've replaced
with a little rearrangement and epicsTimeFromTimespec(). There were also
trivially some header files that had been included by drvTS.h as well.
It now builds, but I haven't yet done the calls to iocClockRegister to
make it supply the IOC time. Is that sufficient to make it work in the
absence of drvTS and generalTime, or do I need at least one of them?
(provided of course that the timing system stays alive - I know that
I'll have no fallback until I implement generalTime)
Peter Denison, Senior Software Engineer
Diamond Light Source Ltd., Diamond House, Chilton, Didcot, Oxon, OX11
0DE
Tel: +44 1235 778511
- Re: drvTS Korhonen Timo
Agilent 89410A Peter Mueller
<2007>
symbDev in 3.14? Sue Witherspoon
<2007>
