Here's a description of the DISP field from the record reference manual. DISP Disable putFields If this field is set to TRUE, then all dbPutFields (normally issued by channel access) directed to this record are ignored except to the field DISP itself. We used the permissive record back in early EPICS days. As Andrew mentioned, it was used for communicating between two or more programs. We used it primarily to communicate to/from the sequencer, but I haven't used it in application for many years. Deb ************************** Deb Kerstiens LANL AOT_IC [email protected] **************************
ANJ, 10 Nov 2011 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
