You need to disable the interrupts before issuing the reboot. You can
do this automatically by adding a reboot-hook function in your driver.
> -----Original Message-----
> From: John Dobbins [mailto:[email protected]]
> Sent: Thursday, March 22, 2007 11:54 AM
> To: EPICS Tech-Talk
> Subject: vxWorks, IP-OCTAL-232, interrupt, and reboot
> Dear All,
> I am trying to create device support for doing data
> acquisition that is
> synchronous with the AC line. I happen to have an
> IP-OCTAL-232 which has
> some general purpose inputs which can be used to generate
> interrupts so
> I am using a pulser synchronized to the AC to trigger the IP-OCTAL.
> I have installed the IP-OCTAL on an MVME-162 running VxWorks 5.4 and
> EPICS 3-13-10. Everything appears to work in that the
> interrupt handler
> gets called (right now the interrupt handler simply clears the
> interrupt source and increments a counter). However if I then type
> "reboot" at the VxWorks console it hangs. If I first disconnect the
> interrupt source (pulser) before typing "reboot" then it does
> not hang.
> Any ideas on what would prevent reboot from occurring?
> Regards and thanks,
> John Dobbins
> Lab for Elementary Particle Physics
> Cornell University
> I am not currently using drvIpac though I copied from drvIpMv162.c :
> This code sets up the interrupt:
> int acClkSetup( ) {
> int slot;
> /* Initialise the IPIC chip */
> for (slot = 0; slot < IPIC_SLOTS; slot++) {
> ipic->intCtrl[slot][0] = IPIC_INT_ICLR;
> ipic->intCtrl[slot][1] = IPIC_INT_ICLR;
> ipic->genCtrl[slot] = IPIC_GEN_WIDTH_8;
> /* using ipac interrupt request line 0 */
> ipic->intCtrl[IP_OCTAL_IPIC_SLOT][0] = (AC_CLK_ILVL &
> IPIC_INT_LEVEL)
> | (ipic->intCtrl[IP_OCTAL_IPIC_SLOT][0] & ~IPIC_INT_LEVEL);
> /* setup memory space for the ipac, interrupt vector goes into
> memory space on MVME-162 */
> ipic->memBase[IP_OCTAL_IPIC_SLOT] = 0x8000;
> ipic->memSize[IP_OCTAL_IPIC_SLOT] = 0;
> ipic->genCtrl[IP_OCTAL_IPIC_SLOT] |= IPIC_GEN_MEN;
> /* install the interrupt handler */
> if (intConnect(INUM_TO_IVEC(AC_CLK_IVEC), acClkMain, 0)
> == ERROR) {
> perror(" Unable to install AC clock interrupt handler\n");
> return -1;
> /* setup SCC2698 interrupt mask register */
> *((char *)IP_OCTAL_IMRA_REG) = (char)IP_OCTAL_IMRA_VALUE;
> /* ivec goes to first byte of ipac mem space */
> *((char *)0x80000000) = (char) AC_CLK_IVEC;
> /* setup Aux. Control Register */
> *((char *)IP_OCTAL_ACRA_REG) = (char)IP_OCTAL_ACRA_VALUE;
> /* enable interrupts on ipic */
> ipic->intCtrl[IP_OCTAL_IPIC_SLOT][0] |= IPIC_INT_ICLR;
> ipic->intCtrl[IP_OCTAL_IPIC_SLOT][0] |= IPIC_INT_IEN;
> sysIntEnable(AC_CLK_ILVL);
> printf(" Setup AC Clk Interrupt\n");
> return 0;
> unsigned int cnt = 0;
> volatile char temp;
> void acClkMain()
> /* clear interrupt */
> temp = *((char *)IP_OCTAL_ACRA_REG);
> cnt++;
> return;
- Re: vxWorks, IP-OCTAL-232, interrupt, and reboot John Dobbins
- vxWorks, IP-OCTAL-232, interrupt, and reboot John Dobbins
CALC record weird behaviour Oleg A. Makarov
<2007>
<2007>
ANJ, 10 Nov 2011 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
