Mark is right: There are still two CA servers in EPICS base.
rsrv - The old server (C) that is running as part of the iocCore
cas - The new server (C++) that is running as part of several host-side
applications (e.g. CA-Gateway)
The new server implements the additional configuration options (which
are heavily used by e.g. the CA-Gateway), the old server doesn't (so the
IOC can't make use of it).
Ralph
For your application, using a virtualization layer (VMware, xen or
similar) that provides a virtual machine with only one of the NICs may
be feasable.
Emmanuel Mayssat wrote:
"In R3.14 and previous releases the CA server employed by iocCore does not implement this feature."
Isn't R3.14(.9) the latest release of the EPICS base?
It is according to http://www.aps.anl.gov/epics/index.php
In other words, are you telling me that this is documented but not
implemented yet?
- Another Dual NICs question Emmanuel Mayssat
- RE: Another Dual NICs question Mark Rivers
- RE: Another Dual NICs question Emmanuel Mayssat
vxWorks, IP-OCTAL-232, interrupt, and reboot John Dobbins
<2007>
EPICS/BluIce gateways Emmanuel Mayssat
<2007>
ANJ, 10 Nov 2011 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
