Andrew recently sent good instructions on setting EPICS_TIMEZONE=CUS::360:040402:103102 or EPICS_TIMEZONE=EUS::300:040402:103102 or ... depending on where you are around to world to instruct vxWorks about the current daylight saving time rules, which changed this year for the US. At runtime, however, vxWorks only cares about TIMEZONE=... So on a running IOC, you use putenv("TIMEZONE=EUS::300:040402:103102") and all is fine. No reboot. So we figured that we add this putenv("TIMEZONE=...) to our startup files, in order to get the time right when an IOC needs a reboot. Very bad idea. If you want to add this putenv call to your startup files, _you_must_use_ EPICS_TIMEZONE. Set EPICS_TIMEZONE, either via putenv() in your startup file or by compiling EPICS base with a properly configured CONFIG_SITE_ENV. Don't set TIMEZONE. In case you have other code besides EPICS on the CPU that needs a correct TIMEZONE, load EPICS first, which will set TIMEZONE from EPICS_TIMEZONE.
epicsTimeLoadTimeInit::epicsTimeLoadTimeInit () { static const time_t ansiEpoch = 0; double secWest; { time_t current = time ( NULL ); time_t error; struct tm date; int status = epicsTime_gmtime ( ¤t, &date ); assert ( status == epicsTimeOK ); error = mktime ( &date ); assert ( error != (time_t) - 1 ); secWest = difftime ( error, current ); } On Unix, and maybe RTEMS, all is fine. But on vxWorks, two things happen: 1) epicsTime_gmtime(), calling vxWorks' gmtime_r(), does not initialize date.tm_isdst. It's left with whatever was on the stack for 'date'. Possibly bad. In any case, mktime converts the date with the TIMEZONE settings, so secWest includes the DST offset if you had TIMEZONE set before loading this code. 2) Later on, the code assumes that "secWest does not include a DST offset", and computes an epoch offset for 1970..1990 that's 1 hour off. In some cases you might not notice any problem because the 1 hour off cancels out. We had major problems because our IOCs run code that compares the timestamps received via NFS, the SNS timing system, and the local IOC clock, and alarms if they don't match within a certain limit. 1 hour off was too much. Thanks to Dave Thompson, Andrew Johnson, Jeff Hill for figuring this out.
ANJ, 10 Nov 2011 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
