>>> Kay-Uwe Kasemir <[email protected]> 3/16/2007 9:44 AM >>>
On Mar 16, 2007, at 10:25 , David Dudley wrote:
> Adding the 'class' keyword to line 130 of the 'LibIO/DataFile.h'
> file did fix that problem.
OK.
> Now, I have an error (much farther down in compiling) that says:
The good news is that you're about as far down with compiling as
you'll get.
/usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -
D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -
D_REENTRANT -ansi -g -Wall -D ARCH_VERSION=2 -D ARCH_RELEASE=9 -
D ARCH_PATCH=2 -D ARCH_VERSION_TXT=\"2.9.2\" -I/home/daviddu/include -
I/usr/local/EPICS/base/include -I/usr/local/EPICS/base/include/os/
Linux -I/usr/local/xerces-c-src2_4_0/include -I${prefix}/
include -g -I. -I.. -I/usr/local/EPICS/include/os/Linux -I/usr/
local/EPICS/include -I/usr/local/EPICS/base/include/os/Linux -I/usr/
local/EPICS/base/include -I/usr/local/EPICS/include/os/Linux -I/usr/
local/EPICS/include ../main_standalone.cpp
> ../main_standalone.cpp:13:26: error: xmlrpc_abyss.h: No such file
> or directory
Following the admittedly lengthy stuff in the manual's Setup/
Installation section,
I end up with /usr/local/include/xmlrpc_abyss.h.
Do you have that?
In addition, the program "xmlrpc-c-config" should be on the PATH.
Is it?
With that,
ChannelArchiver/XMLRPCServer/xmlrpc-config-wrapper server-flags
should produce something like "-I/usr/local/include".
Does it?
Or does that result in the "-I${prefix}/include" which probably
won't work?
-Kay
OK, missed something in the manual, I guess. Under Gentoo, I have
installed:
dev-java/xmlrpc = version 1.2_beta-r1
dev-libs/xmlrpc-c = version 1.06.03
In /usr/include, I have:
find . -name 'xmlrpc*'
./xmlrpc_server.h
./xmlrpc_server_abyss.h
./xmlrpc_cgi.h
./xmlrpc_client.h
./xmlrpc_server_w32httpsys.h
./xmlrpc-c
./xmlrpc.h
I have xmlrpc_server_abyss.h, but not a xmlrpc_abyss.h.
I do have xmlrpc-c-config in my path, but when I do the
'XMLRPCServer/xmlrpc-config-wrapper server-flags' command, I get
'-I$(prefix)/include' as a result.
Did I miss installing something?
David
BEGIN:VCARD
VERSION:2.1
X-GWTYPE:USER
FN:David Dudley
TEL;WORK:880-3740
ORG:;MIS
TEL;PREF;FAX:880-3741
EMAIL;WORK;PREF;NGW:[email protected]
N:Dudley;David
END:VCARD
Re: Problem with compiling Channel Archiver Kay-Uwe Kasemir
<2007>
<2007>
