1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: EDM Related Displays
To: Robert Emery <[email protected]>
Cc: [email protected]
Date: Fri, 02 Mar 2007 13:08:37 -0800
I use medm, so not sure about the capabilities of edm.
If I wanted to do what you want with medm,
I probably would look at a window matching utility, such as Sawfish's
"Matched Windows" or devilspie.
Emmanuel Mayssat
Lyncean Technologies, Inc.
On Fri, 2007-03-02 at 12:51 -0800, Robert Emery wrote:
> I am using edm to set up operator displays. There are instances where I
> would like to open an edm display using a related display button and at
> the same time have another edm display (not the one with the related
> display button in it) close.
> For example, I have a main menu display along the left of the screen and
> a beamline display along the bottom. I would use related display
> buttons in the main menu display to call up different beamline
> displays. If a new beamline related display was selected from the main
> menu, I would like it to open and I would like the existing beamline
> display (that had previously been opened from the main menu) to close.
> Any ideas?
> Thanks
> Robert Emery
> UW Medical Center
EDM Related Displays Robert Emery
Prev: Re: epics / fpga Emmanuel Mayssat
Next: Re: EDM Related Displays Kay-Uwe Kasemir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: EDM Related Displays Robert Emery
ANJ, 10 Nov 2011 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
