At Jlab, we've got (50-60% so far of) our IOC serial ports connected to Cyclades Corporation T-series Terminal servers (http://www.avocent.com/web/en.nsf/Content/Cyclades-TS). These terminal servers are available in 1, 4, 8, 16, and 32 port flavors, run an embedded linux. As I recall, these costed about $100/port at the 16 or 32 port size, and more/port at the smaller configurations. These are simple, little appliances requiring minimal configuration. You basically just have to provide it with network settings, connect the incoming serial lines from the iocs and edit a config file named portslave.conf. Some nice features: - They will buffer the serial console output which can be stored locally (in flash RAM, not much space), written to an NFS mounted filesystem (one logfile/serial port), or sent via syslogs to a loghost. - The serial port may be accessed in r/w mode by one user and simultaneously in read-only mode by others. - Users can be required to authenticate on a per-port basis against a local password or externally (in our case via a radius server) - We have configured it so that users can ssh directly to the serial port and need not first telnet to the terminal server. - We turn it off, but you can also enable the built in web server on the console server and allow users to connect to the logs/terminals via a web browser. I'd be happy to follow-up with more information if requested. -Theo
ANJ, 10 Nov 2011 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
