Kay,
My understanding is that tNetTask takes care of all network stack labor that
can't be done in the threads calling socket entry points, and is also
inappropriate for execution at interrupt level.
We have long suspected that there is a flaw in the vxWorks implementation
where its IP kernel can get sick if thread activity running at priorities
higher than tNetTask preempt tNetTask for too long. Hopefully this will
improve over time. For now we have acquiesced to run most of EPICS at a
priority below tNetTask.
What isn't well understood (at least by me) is the maximum duration of a
tNetTask preemption of lower priority threads such as the scan tasks.
> Doesn't a tNettask at a high priority mean that even if we
> otherwise move all the CA tasks to the bottom, network
> traffic will still disturb the scanning?
No question that for proper degradation under load that the CA server needs
to run at a priority below the scan tasks. That design decision is I think
orthogonal to any defects that may or may not exist in the vxWorks
implementation.
Jeff
> -----Original Message-----
> From: Kay-Uwe Kasemir [mailto:[email protected]]
> Sent: Thursday, March 01, 2007 7:44 AM
> To: tech talk
> Subject: Re: task priorities, busy cpu, and timeout
> On Mar 1, 2007, at 06:27 , Benjamin Franksen wrote:
> > I have made a start by quickly compiling teh following table from
> > vxWorks
> > console output and what I found in the sources. It might be incomplete
> > and/or erroneous.
> For what it's worth, I think
> > ipToAsciiPr 189 10=Low ???
> is the task that CA uses to resolve host names for IP addresses.
> > Apart from filling in missing information (see question marks), it
> > might be
> > sensible to have some sort of rationale for the relative
> > priorities. For
> > instance, it is unclear to me why the timerQueue task has higher
> > priority
> > than cbLow task.
> I'm really unclear about another task where I wonder if it
> disturbs the intended order of things:
> On vxWorks, there's the "tNetTask" at a very high priority.
> At the SNS, we have had problems whenever that task doesn't get
> to run as often as it wants to. When computations that can take
> millisecs run higher than tNetTask, the result is an irrecoverable
> messup of the network stack, at least with our 5.5.1 kernels
> on MVME 2100 CPUs.
> It might make sense that the network chips require to be serviced
> right away, or maybe that's just an imperfection in our version
> of the network code, fixed in more recent vxWorks versions,
> but in any case:
> -Kay
> > EPICS TASKS
> > NAME VX_PRI OSI_PRI DESCRIPTION
> > ts_Casync 109 90=High drvTS (apsEvent module)
> > TSwdIncTime 109 90=High drvTS (apsEvent module)
> > cbHigh 128 71=ScanHigh+1 callback task (prio=high)
> > timerQueue 129 70=ScanHigh scan task
> > scanOnce 129 70=ScanHigh scan task
> > scan0.1 133 66=ScanLow+6 scan task
> > scan0.2 134 65=ScanLow+5 scan task
> > cbMedium 135 64=ScanLow+4 callback task (prio=medium)
> > scan0.5 135 64=ScanLow+4 scan task
> > scan1 136 63=ScanLow+3 scan task
> > scan2 137 62=ScanLow+2 scan task
> > scan5 138 61=ScanLow+1 scan task
> > scan10 139 60=ScanLow scan task
> > timerQueue 139 60=ScanLow epicsTimer
> > cbLow 140 59=ScanLow-1 callback task (prio=low)
> > asCaTask 142 57=ScanLow-3 access security
> > CAC-UDP 147 52=Medium+2 CA client
> > timerQueue 148 51=Medium+1 epicsTimer
> > CAC-event 148 51=Medium+1 CA client
> > dbCaLink 149 50=Medium CA links (client? server?)
> > poolPoll 149 50=Medium ???
> > CAC-event 178 21=CAServerLow+1 CA Server
> > CAS-TCP 181 18=CAServerLow-2 CA Server
> > CAS-beacon 182 17=CAServerLow-3 CA Server
> > CAS-UDP 183 16=CAServerLow-4 CA Server
> > errlog 189 10=Low errlog
> > taskwd 189 10=Low task watchdog
> > CAC-repeate 189 10=Low CA Client (repeater)
> > Cheers
> > Ben
> > "Programming = Mathematics + Murphy's Law" (Dijkstra in EWD1008)
- task priorities, busy cpu, and timeout Dennis Nicklaus
- Re: task priorities, busy cpu, and timeout Andrew Johnson
- Re: task priorities, busy cpu, and timeout Benjamin Franksen
- Re: task priorities, busy cpu, and timeout Kay-Uwe Kasemir
RE: task priorities, busy cpu, and timeout Jeff Hill
<2007>
<2007>
