1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: ca_sg_put problem with DISP=1
To: Dirk Zimoch <[email protected]>
Cc: TechTalk EPICS <[email protected]>
Date: Wed, 28 Feb 2007 17:14:31 -0600
Dirk Zimoch wrote:
I got a strange effect with ca_sg_put if writing to a record where DISP=1.
The ca_sg_put succeeds (returns ECA_NORMAL) but then,
an error message is printed asynchronously:
CA.Client.Exception...............................................
Warning: "Channel write request failed"
Context: "op=1, channel=DZ-AO3, type=DBR_invalid, count=0, ctx="write notify request rejected""
Source File: ../syncGroupWriteNotify.cpp line 98
Current Time: Wed Feb 28 2007 16:40:34.421658000
Finally, ca_sg_block times out, long after it was clear to CA that writing failed.
Especially the last point is strange to me. Is this a bug or is it designed this way?
If you look at the documentation for ca_sg_block(), which is at
http://www.aps.anl.gov/epics/base/R3-14/9-docs/CAref.html#ca_sg_block
You'll see that it doesn't currently have any return code that means "operation failed". ECA_NORMAL means success so it can't return that, and if the time period you specified hasn't passed yet then ECA_TIMEOUT isn't appropriate. The other two codes documented are associated with bad arguments, so it must have been designed to work that way.
If it works as intended, what is the correct way to handle failing synchronous writes to records with DISP=1 without timing out?
What is setting the record's DISP field, and why do you expect any different behaviour than that which you're seeing? The DISP field is documented in the Record Reference Manual as meaning "disable/ignore all puts to other fields of this record" and CA flags that as a failure. The CA timeout operations don't mean "retry the operations for this time period"; if you want retries you'll have to code them yourself I'm afraid.
I think you may have discovered one reason why the ca_sg_ functions aren't quite as useful as they initially seem, which is probably why they're not used very much.
- Andrew
The right to be heard does not automatically include
the right to be taken seriously. -- Hubert H. Humphrey
Re: ca_sg_put problem with DISP=1 Dirk Zimoch
Prev: Re: task priorities, busy cpu, and timeout Andrew Johnson
Next: RE: task priorities, busy cpu, and timeout Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: ca_sg_put problem with DISP=1 Dirk Zimoch
Next: Re: ca_sg_put problem with DISP=1 Dirk Zimoch
ANJ, 10 Nov 2011 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
