Dennis Nicklaus wrote: We have a Motorola MVME 5500 CPU running Epics on VxWorks. It'sdoing some cpu-intensive computations and runs about 37% idle. Our problem is that this makes EPICS connectivity iffy, resulting in a timeout to a client doing a caget (for example) about 20% of the time. Is processing load continuous, or do you get periods of time (seconds or more long) when there's no idle at all and others when there is? If your system behaves like that then I can see why your CA connectivity might be poor for some applications (the default timeout for caget is 1 second, although you can change that with the -w option). A large fraction (about half) of the used cpu time is spent in the Epics cbLow task, processing genSub record routines which are processed based on an epics "event" scan field (posted at about 1Hz). (see spy output below) Sorry, there probably should be but no such document exists. Your guess is right. The three cbXxx tasks are for general-purpose operations that need to happen in task context Can I lower the priorty of the cbLow task (to below that of the CAS-client tasks) and still expect epics to work correctly? Actually you probably can - the core code shouldn't notice, but you will need to be aware that doing this permits CA clients to affect the internal operation of the IOC. The reason why all CA tasks are lower than the database tasks is that the IOC's most important job is usually to execute the process database, and when we're running out of time we'd much rather drop networking activities than record activities. Why do the genSub event-driven records get processed in cbLow? Is it because they are genSubs or because they are event-driven? The latter; record processing can occur in several different tasks, but the cbXxx and the periodic scan tasks are the main ones. It's a relatively new system and re-designing our software in light of the cpu-usage is certainly possible, but we'd like to know more about the epics priorities and how exactly a client gets a channel access timeout before proceeding. We're running epics 3.14.8 on vxworks 6.1 if it makes any difference. The longer running clients like EDM and MEDM, StripTool and ALH should connect eventually. I suspect you'll have the most trouble with any scripts or similar short running programs that aren't expecting the connection process to take longer than a second. If you can increase their timeouts that may be sufficient to solve the problem. - Andrew -- The right to be heard does not automatically include the right to be taken seriously. -- Hubert H. Humphrey
ANJ, 10 Nov 2011 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
