J. Frederick Bartlett wrote:
Recently we have been having problems with IOC timestamp
synchronization on our EPICS network. The timing master is unable to
obtain timing information from our ntp server -- see Geoff Savage's
techtalk note on 15 Feb 2007. While we are finding the solution to that
problem, I would like to make one of our IOC's a timing master and set
its clock to approximately the correct time. Does anyone know of a
method of setting the IOC's clock from the vxWorks shell?
Unfortunately there's no way to do that with the current vxWorks IOC
clock implementation. The code for the vxWorks IOC clock in R3.14 is
found in base/src/libCom/osi/os/vxWorks/iocClock.c - look at the
iocClockInit() and syncNTP() routines for starters. That's also where
you'll see how we find the NTP server to use.
- Andrew
The right to be heard does not automatically include
the right to be taken seriously. -- Hubert H. Humphrey
- Setting an IOC clock from the vxWorks shell J. Frederick Bartlett
Re: Orderly IOC shutdown? Michael Abbott
<2007>
RE: Setting an IOC clock from the vxWorks shell Thompson, David H.
<2007>
ANJ, 10 Nov 2011 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
