Hello,
I am writing portDriver for aio card. I read some data from asynInt32 and asynInt32Array interface type:
static asynInt32 drvAio16Int32 = {
NULL,
readInt32,
getBounds,
NULL,
NULL
static asynInt32Array drvAio16Int32Array = {
NULL,
readInt32Array,
NULL,
NULL
Ok interfaces inicialization and ....
pPvt->common.interfaceType = asynCommonType;
pPvt->common.pinterface = (void *)&aio16Common;
pPvt->common.drvPvt = pPvt;
pPvt->int32.interfaceType = asynInt32Type;
pPvt->int32.pinterface = (void *)&drvAio16Int32;
pPvt->int32.drvPvt = pPvt;
pPvt->int32Array.interfaceType = asynInt32ArrayType;
pPvt->int32Array.pinterface = (void *)&drvAio16Int32Array;
pPvt->int32Array.drvPvt = pPvt;
And asynInt32Array adn asynInt32 read methods are as follows
static asynStatus readInt32( void *drvPvt, asynUser *pasynUser, epicsInt32 *value )
drvAio16Pvt *pPvt = (drvAio16Pvt *)drvPvt;
rtems_unsigned8 channel;
rtems_unsigned16 data, size;
pasynManager->getAddr(pasynUser, &channel);
some code (calculating...)
*value = ( epicsInt32 )data_buffer[0];
asynPrint(pasynUser, ASYN_TRACEIO_DRIVER,
"drvAio16, port %s, read %d from channel %d\n",
pPvt->port_name, *value, channel);
return asynSucces;
/* Asyn Waveform read routine */
static asynStatus readInt32Array(void *drvPvt, asynUser *pasynUser, epicsInt32 *value, size_t nelements, size_t *nIn)
rtems_unsigned32 read_samples, i;
return asynSucces;
When I run episc database in which I have some ai record type everything working fine but when I add waveform record type I get following error:
fatal error: dbScanLock. Bad case choice.
So what it's different between asynInt32 and asynInt32array read routine? Why asynInt32 read routine work but asynInt32Array read routine crash?
Episc version: 3.14.8.2
Asyn version: 4.3
Build target RTEMS-pc386
Thanks in advance!
