1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Java IDE & graphic library
To: tech talk <[email protected]>
Date: Thu, 22 Feb 2007 14:26:03 -0500
On Feb 22, 2007, at 12:06 , Claude Saunders wrote:
- Claude "I don't use an IDE, but that doesn't stop me from having an opinion." Saunders
In the (distant) past, I had used Turbo Pascal, Borland C++,
Visual Studio, KDeveloper, and every time came back
to vi, make, emacs.
Eclipse was the first IDE that really appealed to me
- it doesn't force you to create your project in a specific way.
You can locate your sources and binary in pretty much any place,
and also import existing projects.
- the java support is really nice: completion, compile-as-you-type
error checking
- the absolute killer is the refactoring.
Not just rename classes, but extract sections of code into their
own subroutine, extract methods into interfaces etc.
All that is perfectly usable for plain Java code that before or after
being edited inside Eclipse bears no mark of ever having been in
contact with it.
Netbeans might be similar, I don't know.
I didn't like the Eclipse GUI interface builder.
Maybe because it only really works well on Win32,
maybe because I never liked any GUI interface builder.
-Kay
Re: Java IDE & graphic library Christopher Larrieu
Java IDE & graphic library Lecorche Eric
Re: Java IDE & graphic library Claude Saunders
Prev: asynDriver, problem with asynInt32Array read routine Janez Golob
Next: Re: Java IDE & graphic library Christopher Larrieu
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: Java IDE & graphic library Pearson, MR (Matthew)
ANJ, 10 Nov 2011 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
