Rock, Judith E. wrote:
Hi -
We're setting up an alarm handler tree, and plan to use the FORCEPV feature for temporarily disabling alarming for branches of the tree. All is working wonderfully.
Except...when I start a new alarm handler display while a group FORCEPV has been previously set to forceValue (i.e. group disabled). The group mask of the disabled group is set to the proper force mask at startup, but its alarm severity on the display and the alarm severities of the parent groups still show an alarm state. The only way the group severity gets set properly is to change its FORCEPV to resetValue, and then back to forceValue. I.e., the FORCEPV for a group is only picked up upon transition from resetValue to forceValue while alh is running, not at alh startup.
Is there a way to trigger the proper group alarm severities at startup?
I did notice that the force severity at startup works properly at the channel level.
Sorry if I've missed something really obvious!
thanks for your help,
Judy, et al at SLAC
Hi Judy,
We have run into the same problem. Our workaround has been to use the
FORCEPV for each channel in the group instead of using it at the group
level. This seems to work properly, though it is a bit of a pain. If the
channels have their own FORCEPV's then you can use FORCEPV CALC's to get
the same effect.
This is pretty easy for us to do since our alh files are generated
semi-automatically by scripts. It would be more of a hassle for
hand-edited alh files.
Brian S. Bevins, PE
Computer Scientist / Mechanical Engineer
Thomas Jefferson National Accelerator Facility
"Progress, far from consisting in change,
depends on retentiveness. Those who cannot
remember the past are condemned to repeat it."
-- George Santayana
- alarm handler question: group FORCEPVs and severities at alh startup Rock, Judith E.
Re: evaluation of OMG DDS as a controls protocol for EPICS Lawrence T. Hoff
Re: EPICS and HEPiX @ DESY - make your hostel reservations! Matthias Clausen
<2007>
time synchronization Geoff Savage
<2007>
