1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: EPICS Base R3.14.9-RC1 Released
To: [email protected]
Date: Fri, 26 Jan 2007 23:46:07 +0100
On Friday 26 January 2007 22:12, Andrew Johnson wrote:
> The first Release Candidate of EPICS Base version 3.14.9 is now
> available for download from the website.
> 	http://www.aps.anl.gov/epics/base/R3-14/9.php
> This code has gone through testing by the EPICS core developers at a
> number of sites on various different architectures without showing any
> significant bugs, and at this point we would like to ask others in the
> community to try it out and report any problems that you find with it.
> There are a couple of known problems which we are not currently
> intending to fix - see the KnownProblems documentation for details.
> If there are no reports of any significant bugs in the next week
> (actually I'll make that Monday 5th of February) then I will re-release
> this code as the official R3.14.9 release.
>From the release notes:
dbLoadTemplate
The parser for the substitutions file accepted by dbLoadTemplate() has been
revised, and is now stricter than it used to be â unmatched characters that
were accepted and discarded without warning before will now generate
errors. The quote characters at the two ends of a quoted string value must
now match, although either single or double quotes can be used. Escaped
characters inside a quoted string should pass safely through to the
underlying dbLoadRecord() command. The characters permitted in a bareword
parameter (i.e. a filename or value that is not inside quotes) have been
reduced from the overly wide set allowed before; the permitted characters
now comprise: a-z A-Z 0-9 _ - + : . / \ [ ] < > ;
I am a bit astonished about this. This whole change, but especially the last
one, introduces a major incompatibility. I would have expected at least a
note to tech-talk beforehand, inviting requests for comments from concerned
parties. I am astonished about this because in many other respects
compatibility on the database level has been a top-priority for EPICS
(sometimes pursued almost to the point of stiffling progress).
I would be interested to hear of the rationale i.e. what is the great
improvement, considering the possible disruption such an incompatible
change may cause, and also considering that 3.14.9 has been advertised as
a 'mostly bug-fix' release?
One further issue that I would be interested in is: will the corresponding
tool on the host side (MSI) be adapted according to the new rules, so that
inflating substitutions on host and target side will remain equivalent? (Or
have they ever been after dbLoadTemplate was no longer available on the
host side?)
Ben
"Prevention is better than cure, in particular if the illness is unmastered
complexity, for which no cure exists." [E.W.Dijkstra]
Re: EPICS Base R3.14.9-RC1 Released Andrew Johnson
Prev: EPICS Base R3.14.9-RC1 Released Andrew Johnson
Next: MEDM behavior, can't type in text edit box. Michael Urashka
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: EPICS Base R3.14.9-RC1 Released Andrew Johnson
ANJ, 10 Nov 2011 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
