1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: EPICS Driver for motor through Ethernet/Serial?
To: "Denison, PN \(Peter\)" <[email protected]>
Cc: [email protected], tech-talk <[email protected]>
Date: Mon, 22 Jan 2007 08:08:09 -0600
Peter:
Sourceforge reports that link is missing part of its path. Here's the path that works for me:
http://epics.svn.sourceforge.net/viewvc/epics/applications/tags/tpmac/3-3/
  Pete
Pete R. Jemian, Ph.D.                <[email protected]>
Beam line Controls and Data Acquisition, Group Leader
Advanced Photon Source,   Argonne National Laboratory
Argonne, IL  60439                   630 - 252 - 3189
   Education is the one thing for which people
      are willing to pay yet not receive.
Denison, PN (Peter) wrote:
It would help if you gave a few more details about the exact model of motor.
The latest release of the motor support (R6-1, from http://www.aps.anl.gov/upd/people/sluiter/epics/motor/R6-1/motorR6-1.tar.gz) includes a driver for Newport motor controllers, using Asyn as the low-level protocol to talk to the motor controller. There is also a driver for Delta-Tau motor controllers (tpmac at http://epics.svn.sourceforge.net/epics/applications/tags/tpmac/3-3/) which also uses this release of motor support, and serial Asyn as the lowest layer transport to the motor controller.
To support your motor, you could have a look at one of these, and adapt it to talk the protocol required by your serial-port motor. The ethernet/serial converter box should be transparently supported by Asyn, if you're lucky.
Peter Denison, Senior Software Engineer
Diamond Light Source Ltd., Diamond House, Chilton, Didcot, Oxon, OX11 0DE
Tel: +44 1235 778511
    *From:* [email protected] [mailto:[email protected]]
    *Sent:* 22 January 2007 07:20
    *To:* tech-talk
    *Subject:* EPICS Driver for motor through Ethernet/Serial?
hi,
I want to find a EPCIS 314 driver for a motor which has a serial
port, connected to an Ethernet/Serial converter boxes, IOC is redhat
linux. all the control string is ASCII code. Is there somebody using
Asyn driver to implement this? Can you send me an application?
Thanks a lot for your help.
Best wishes
Geyang 2007/1/22
RE: EPICS Driver for motor through Ethernet/Serial? Denison, PN (Peter)
Prev: RE: EPICS Driver for motor through Ethernet/Serial? Mark Rivers
Next: Re: Out of order replies from a serial device Phillip Sorensen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: asyn driver for serial device marco_hair
ANJ, 10 Nov 2011 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
