Hi Mike,
you can try to switch on debugging (var streamDebug 1) to see what's going on inside StreamDevice.
This may produce a lot debugging output. Better only switch it on after iocInit.
StreamDevice should be able to handle null characters. Of course there may be a bug inside
StreamDevice that crashes the ioc under certain conditions. I need more detailled information about
the error conditions.
Can you send me your records and protocol file? What is your operating system?
I guess the "Killed" message comes from the operating system. It does not come from StreamDevice or
asyn or EPICS base. You can try to switch on core dumps (ulimit -c unlimited) before starting your
IOC and analyse it with a debugger.
Dirk
Mike Forster wrote:
Hi folks,
We've got a new ioc that controls a power supply over RS-232 with
StreamDevice. When the control power on the power supply is cycled, the
ioc dies with only the message "Killed". (Specifically the ioc dies
when the PS is turned back on.)
Turning on asyn tracing shows that upon turning the PS back on, some
extra data like null characters are read in through StreamDevice.
(Perhaps data that was interrupted?) On reading this, the ioc dies.
The mismatch exception handling is turned on, but I'm not quite sure
what command to put inside the handler to deal with this problem. I've
tried several ideas but none seem to work.
Using epics 3.14.8.2 <http://3.14.8.2>, streamDevice 2-1, and asyn 4-6.
(Also tried with 3.14.7, 2-1, and 4-3)
Any ideas on what could be going on that the ioc can't handle?
Mike Forster
Wilson Lab
Cornell University
Dr. Dirk Zimoch
Swiss Light Source
Computing and Controls
Paul Scherrer Institut
phone +41 56 310 5182
fax +41 56 310 4413
- StreamDevice ioc dying Mike Forster
Re: StreamDevice ioc dying Eric Norum
Re: Re: VME-based arbitary function generator Damjan Golob
<2007>
EPICS driver for Libera released Michael Abbott
<2007>
