Have you tried running the IOC under GDB? (assuming you're running
this on Linux or Darwin) You can then do some post-mortem
investigations.
On Jan 11, 2007, at 11:07 AM, Mike Forster wrote:
Hi folks,
We've got a new ioc that controls a power supply over RS-232 with
StreamDevice. When the control power on the power supply is
cycled, the ioc dies with only the message "Killed". (Specifically
the ioc dies when the PS is turned back on.)
Turning on asyn tracing shows that upon turning the PS back on,
some extra data like null characters are read in through
StreamDevice. (Perhaps data that was interrupted?) On reading
this, the ioc dies. The mismatch exception handling is turned on,
but I'm not quite sure what command to put inside the handler to
deal with this problem. I've tried several ideas but none seem to
work.
Using epics 3.14.8.2, streamDevice 2-1, and asyn 4-6.
(Also tried with 3.14.7, 2-1, and 4-3)
Any ideas on what could be going on that the ioc can't handle?
Mike Forster
Wilson Lab
Cornell University
Eric Norum <[email protected]>
Advanced Photon Source
Argonne National Laboratory
(630) 252-4793
- StreamDevice ioc dying Mike Forster
Re: StreamDevice ioc dying Dirk Zimoch
<2007>
<2007>
ANJ, 10 Nov 2011 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
