With EPICS Base R3.14.8.2, we have experimented with string and waveform records and have noticed that messages are not always delivered to monitor processes when the messages are quickly written to the PV.You're right. I understand the reason is that only the most recent string or waveform is cached on the server side in order to preserve memory, because strings or waveforms can be long (well, EPICS strings are still fixed to char[40]). Double or other 'small' types are queued up, so all your values are eventually sent out, but for strings, your N quick string updates end up as a single monitor for the last string. In a similar case (string record for log messages...) I ended up writing then to my own queue, then a little sequence copied those values slowly (<=10Hz) to the actual PV. Problem 1: If you run out of memory because you queue up more than you ever sent out, you're of course dead. Problem 2: What is slow enough? When is it OK to send another value? Problem 3: Even with 'double' or other data types which are queued up on the server side, you can get into 'flow control' when the client doesn't read fast enough. There is no indication, no log message nor any other info I'd know of that will tell you that you are or ever were in flow control. You simply loose a few messages without ever knowing about it. -Kay
ANJ, 10 Nov 2011 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
