1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: I have a question about using muti IOC
To: Ralph Lange <[email protected]>
Cc: "Hyun Mi, Choi" <[email protected]>, EPICS Tech Talk <[email protected]>
Date: Thu, 04 Jan 2007 11:16:30 -0800
Look at the documentation for those environment variables particularly
the last 2.
EPICS_CA_AUTO_ADDR_LIST=YES
EPICS_CA_REPEATER_PORT=5064
EPICS_CA_SERVER_PORT=5065
and set them at different values BEFORE you start your ioc programs.
EPICS_CA_REPEATER_PORT=5066
EPICS_CA_SERVER_PORT=5067
Emmanuel
> Hyun Mi, Choi wrote:
> > Hello..
> > Excuse me, I have a question about using muti IOC
> > I ran an IOC on Linux computer..
> > System informaion
> > EPICS IOC OS : Radhat Linux9.0
> > EPICS Extensions OS : Radhat Linux9.0
> > EPICS base : Release R3.14.8.2 (IOC, Extensions)
> > We wanna run more one IOC on one Linux...
> > I tried to run two st.cmd files..
> > the error meassage is like below...
> > cas warning : configure TCP port wwas unavailable
> > cas warning : using dynamicaly assigned TCP port 36885
> > cas warning : but now two or more severs share the same UDP port
> > cas warning : Depending on your IP kernel this server may not be
> > cas warning : reachable with UDP unicast (a host's IP in
> > EPICS_CA_ADDR_LIST)
> > I have alreadly read channel access reference manual and found tech
> > tech content..
> > However, I didn't configure to solve this error...
> > How I do configure to solve our problem? We must run multi(two, three
> > or four) IOCs on a Linux computer.
> > Could you say to me a comment or a method?
> > Thank you very much, Happy New Year!
> > from Hyun Mi, Choi
Re: I have a question about using muti IOC Luedeke Andreas
Re: I have a question about using muti IOC Ralph Lange
Prev: Re: [No Subject] Andrew Johnson
Next: Re: I have a question about using muti IOC Luedeke Andreas
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: I have a question about using muti IOC Ralph Lange
ANJ, 10 Nov 2011 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
