Ralph Lange wrote:
I still prefer having different IP addresses for different IOCs on the
same host, as you can find out a lot easier which soft IOC a certain
channel (that an external CA client is connected to) resides on. Useful
when things are hanging and you want to know which of the soft IOCs has
to be rebooted.
How do you get the IOC (which still uses the old RSRV server, not CAS)
to bind to only one particular IP address?
RSRV doesn't make use of the EPICS_CAS_INTF_ADDR_LIST variable for
anything other than its CA beacon addresses, it still listens for client
connections on all interfaces it can find. If those interfaces are on
different subnets then this won't generally be a problem (except for
client programs that are running on that same machine), but for two IPs
on the same subnet this ought to give "duplicate PV" errors to all
clients that try to connect to that IOC.
Am I missing something?
- Andrew
There is considerable overlap between the intelligence of the smartest
bears and the dumbest tourists -- Yosemite National Park Ranger
- Re: I have a question about using muti IOC Ralph Lange
<2007>
<2007>
ANJ, 10 Nov 2011 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
