Hi also- it's not a problem to include the escaped C code
in the same file as the sequence code; it just becomes part
of the file written by snc. I usually insert it before any
state code to avoid the need for forward references.
Note that when()'s are evaluated only when something happens
to wake up the corresponding thread, e.g. a monitored/sync'd
PV update or a delay() expiring; if a state has only when()'s
that wait on C functions, there's not going to be any way for
it to continue (unless one of the when()'s triggers immediately
on initial entry to the state). There needs to be at least one
reference to a sync'd PV or a delay() in some when() in each
state for the seq() task loop to wake up. It doesn't need to
be the one with the C function, since ALL when()'s in a state
are evaluated on ANY event "registered" for that state, but
that also means your C function when() may not happen when you
think it will. In particular, checking a PV _only_ in the escaped
code won't make the compiler notice that you want to wake up
when that PV changes.
What sort of compiler errors were you getting?
Mike
-----Original Message-----
Sent: Wednesday, January 03, 2007 11:32 AM
To: Dennis Nicklaus; [email protected]
Subject: RE: C function in when() clause of sequencer
Hi
At the Keck observatory, most of our sequencers call 'C' functions
(hmmm these are sequencers running on vxWorks with EPICS 3.13.10).
Seems to me it is just a matter of linking and loading.
What you proposed should be functional except, I think, the static
for the softCheck function may be a problem as it will exist in a C
source file separate from the SNL file and may not be resolved correctly
(you might have to experiment).
- RE: C function in when() clause of sequencer Al Honey
caRepeater must run before casr Dennis Nicklaus
<2007>
<2007>
