1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Channel Access and Tcl
To: John Dobbins <[email protected]>
Cc: EPICS Tech-Talk <[email protected]>
Date: Tue, 19 Dec 2006 16:23:17 -0600
I maintain oagwish so I would definitely recommend it :) It started with et_wish but has evolved since then. But the basics are still the same. Your command "pv linkw cur PVname" does not set the variable "cur" in the current context, instead it sets the global variable "cur". Also you probably always want to use linkw and putw instead of link and put. This way you don't have to use any pv info commands in some loop waiting for the PV to respond. So your code would look like:
proc my_test {} {
   global cur errorCode
   if {[pv linkw cur bl_mag_crv1_cmd] != 0} {
	puts "error: $errorCode"
	exit
   set cur 0.001
   puts "cur = $cur"
   if {[pv putw cur] != 0} {
	exit
   puts "executed test"
my_test
Hope this helps,
--Bob Soliday
John Dobbins wrote:
Dear All,
(Preface: new to using Tcl so please don't assume I know what I'm doing)
I have built et_wish from the distribution
http://www.aps.anl.gov/epics/download/extensions/caTCL_20020802.tar.gz
I can start et_wish and the various Channel Access commands work fine from the et_wish command line, but when I try to use them from inside a proc they stop working. If inside a proc I use
  pv link variable_name record_name
  pv put variable_name
then the value of the record remains unchanged. See example code below.
1) Does anyone have any ideas about this? (Tcl8.3.5 on Scientific Linux 3)
2) I see that oagwish from APS appears more actively maintained. Should I be using this instead?
Thanks
John Dobbins
This et_wish command line code works:
% pv link cur bl_mag_crv1_cmd
0
% set cur 0.001
0.001
% pv put cur
0
This script does not:
proc my_test {} {
    set x  [pv info cur state]
    puts $x
    set cur 0.001
    puts "cur = $cur"
    pv put cur
after 50
    puts $x
my_test
and has output:
{cur OK}
cur = 0.001
{cur OK}
executed test
Channel Access and Tcl John Dobbins
Prev: Channel Access and Tcl John Dobbins
Next: APS IT Maintenance Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
