As Kazuro already reported, KEKB&PF-AR/KEK are in the process of
replacing HP-UX hosts with Linux/MacOSX/True64(OSF1-Alpha) hosts.
On HP-UX, EPICS 3.13.6 or older are still used for operation.
For Tornado/VxWorks, Sun/Solaris workstation has introduced.
In J-PARC, the project I currently working on, HP-UX machines are thrown
away sometime before and uses mostly Linux for OPI side.
(Personally, I test EPICS software on MacBook, but it is not officially
supported in J-PARC)
So, I think, it will not be a big issue for KEK to drop a support for
HP-UX in the future versions of EPICS.
Noboru
Kazuro FURUKAWA wrote:
> Dear Andrew and Ralph,
>>>> On Tue, 12 Dec 2006 15:01:41 JST, Andrew Johnson <[email protected]> wrote;
>> In order that Ralph's Call For Volunteers receives as wide an audience
>> as possible, I'm forwarding this message to tech-talk (apologies to the
>> core-talk folks who've already seen it once). If your site expects to
>> need to run EPICS R3.14.9 on HP-UX, you should have someone step up now
>> or we may have to drop HP-UX from the list of architectures officially
>> supported by EPICS.
> Are we the only HP-UX EPICS users on the planet?! I'll look into
> our resource, but maybe we don't need newer versions of EPICS on
> HP-UX. So... At KEKB, although I keep two HP-UX machines for
> some reason and I have installed R3.14.8.2, the versions of HP-UXen
> are V10.20 and V11.0 ... They are old and normally run R3.13
> clients.
> Instead, we may be interested in keeping Tru64 and FreeBSD.
> Our main client platforms are Darwin and Tru64. We will re-
> introduce Linux machines again, partially to replace HP-UX. Other
> facilities like Linac, Photon-Factory and J-PARC are using Linux
> as the main EPICS clients.
> FYI, R3.14.8.2 on HP-UX V11.0 mostly works for me. Somehow,
> startup/EpicsHostArch.pl did not work. Other than that, I
> simply modified SHRLIB_SEARCH_FULLPATHDIRS in
> CONFIG_SITE.Common.hpux-parisc, and it worked. Thanks to Ralph!!
> Regards, Kazuro.
>> -------- Original Message --------
>> Subject: EPICS Base @ HP-UX: Volunteers wanted
>> Date: Tue, 12 Dec 2006 15:27:06 +0100
>> From: Ralph Lange <[email protected]>
>> Organization: BESSY
>> To: EPICS Core Talk <[email protected]>
>> Hello everyone,
>> trying to resolve the situation with an outdated C++ compiler crashing
>> on the EPICS sources, I found out that BESSY doesn't seem to be able to
>> support testing Base on HP-UX any longer.
>> We are in the middle of converting to Linux, the software on our few
>> remaining HP-UX machines has been in frozen state for a while, so asking
>> for an update of a compiler to test a software that is not going to be
>> used on that platform
>> ... sounds a lot like asking someone to waste time to be able to waste
>> more time.
>> I know we intended to keep HP-UX supported for 3.14 and I know there are
>> others still using HP machines, so I'm not feeling too happy with this
>> issue. In any case I would like to keep the HP-UX configuration files
>> around for a little longer.
>> Well, I'm throwing the ball high up in the air and start running ....
>> maybe one of the KEK colleagues (the only remaining HP users as far as I
>> know) is able to catch it?!
>> I'm definitely willing to continue helping with ideas and suggestions,
>> if someone takes over. No question. But without a current system and
>> compiler I'm not able to compile nor test.
>> Sorry -
>> Ralph
>> There is considerable overlap between the intelligence of the smartest
>> bears and the dumbest tourists -- Yosemite National Park Ranger
> Kazuro FURUKAWA <[email protected]>
> Linac&KEKB, High Energy Accelerator Research Organization (KEK), Japan
begin:vcard
fn:Noboru Yamamoto
n:Yamamoto;Noboru
email;internet:[email protected]
tel;work:+81-29-864-1171, ext. 5309
tel;fax:+81-29-864-0321
x-mozilla-html:FALSE
version:2.1
end:vcard
- Re: [Fwd: EPICS Base @ HP-UX: Volunteers wanted] Kazuro FURUKAWA
Re: wxPython timer and KEK CaPython314 cause core dump Noboru Yamamoto
Re: [Fwd: EPICS Base @ HP-UX: Volunteers wanted] Ralph Lange
<2006>
Problems with database breakpoint routines. Rees, NP (Nick)
<2006>
