1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: CA gateway question
To: "Jeff Hill" <[email protected]>
Cc: "'Martin L. Smith'" <[email protected]>, "'Ken Evans'" <[email protected]>, "'Ralph Lange'" <[email protected]>, "'EPICS-tech-talk'" <[email protected]>
Date: Fri, 1 Dec 2006 13:19:23 +0900
Hi Jeff,
On Wed, 29 Nov 2006 15:19:58 -0700
"Jeff Hill" <[email protected]> wrote:
> The client library would eventually find the PV in the other gateway, and
> connect through the other gateway. How fast it would switch over depends on
> how it lost contact with the original gateway. If the network path to the
> original gateway was severed it might take a relatively longer amount of
> time to switch over - approximately as long as the TCP keep-alive interval
> parameter specifies.
As I've read in CA documentation, some time ago the behaviour of CA
library was different. The clients tended to start new search just as
soon as they discover that connection is "unresponsive". But in the
current version they wait until TCP connection goes down (and as you
mentioned it may take pretty long time if the connection is not closed
in a "polite" manner). So is there any configuration variable or some
other way to choose which behaviour we need ?
Artem.
RE: CA gateway question Jeff Hill
Re: CA gateway question Martin L. Smith
Prev: RE: CA gateway question Jeff Hill
Next: vmivme5565 driver for epics 3.13 Lei Ge
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: RE: CA gateway question Jeff Hill
