1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Fedora Core 6 & EPICS R3.14.8.2
To: [email protected]
Date: Fri, 24 Nov 2006 21:02:47 +0100
On Friday 24 November 2006 19:49, Billy Adams wrote:
>      OpenMotif was not included in Fedora Core 6 released in Oct.
> 2006, as expected.  But all is not lost yet.  EPICS R3.14.8.2 can be
> compiled and executed using Fedora Core 6.
>      I installed "ALL OPTIONS" when installing Fedora Core 6.
> Installation took a little less than 6 Gigabytes.  The only thing
> else needed is OpenMotif.
>      I took the following two RPM files from Fedora Core 5
> installation CD4 and installed them on Fedora Core 6:
>             openmotif-2.3.0-0.1.9.2.i386.rpm
>             openmotif-devel-2.3.0-0.1.9.2.i386.rpm
>      Next I compiled EPICS R3.14.8, then the facility code, and
> executed the facility code.  It works!
FWIW, installing openmotif-2.3.0 (beta) from source (on an amd64
debian-testing) went absolutely straight forward for me. In contrast to
older versions of OpenMotif, which had a strange build system, the
latest versions needs only the usual './configure; make; make install'
routine. (You might, however, need to install one or two additional
devel packages from your distro.)
Ben
Re: Fedora Core 6 & EPICS R3.14.8.2 Noboru Yamamoto
vmivme5565 driver for epics 3.13 Lei Ge
Fedora Core 6 & EPICS R3.14.8.2 Billy Adams
Prev: Fedora Core 6 & EPICS R3.14.8.2 Billy Adams
Next: Re: Fedora Core 6 & EPICS R3.14.8.2 Noboru Yamamoto
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
