1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: edm questions about "menu mux"
To: marco_hair <[email protected]>
Date: Fri, 24 Nov 2006 13:40:40 -0500
I use it occasionally and have not seen any problems with the current
version.
Send me a simple edl file that demonstrates the problem and I will
investigate. For example, one with a mux and perhaps a static text
object that displays the symbol set by the mux.
Make sure your edmObjects file contains the correct information and also
try doing a clean make.
On Fri, 2006-11-24 at 10:12 +0800, marco_hair wrote:
> hi,
>   Is there anyone using "menu mux" in controls of edm? when I try to
> run it, there is a "Segmentation fault" error . can it work correctly
> on edm-1-11-0s? I compiled the latestet edm on fc3/fc4/fc5, this
> function can't work properly.
>   Any suggestion is appreciated.
> Best wishes
> Geyang 2006/11/24
> SSRF Control Group
> æ ç å å æ å è å ç é å å
> c2 å ç é è ä ç è æ å å å æ ç å å è å å
Attachment: smime.p7s
Description: S/MIME cryptographic signature
edm questions about "menu mux" marco_hair
Prev: edm questions about "menu mux" marco_hair
Next: Fedora Core 6 & EPICS R3.14.8.2 Billy Adams
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
