export LD_LIBRARY_PATH="$LD_LIBRARY_PATH:$EPICS_BASE/lib" export PATH="$PATH:$EPICS_BASE/bin" Hmm. This does of course depend on how EPICS has been installed on the target system, and I suspect that I may have broken the rules in my definition of how EPICS is installed on the Libera electron beam position monitor (this is the environment Yan Ying Bing is using). If you install EPICS as I instruct Libera users: 1. build EPICS 2. run install-epics on the host 3. run libera-install-epics on the target then the following files are installed on the *target*: /opt/epics/lib <- copy of $EPICS_BASE/lib/linux-arm/*.so /opt/epics/bin <- only $EPICS_BASE/bin/linux-arm/caRepeater This is a bit non-standard, but I hope not too confusing. Of course, if this has been done, then we need export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/opt/epics/lib export PATH=$PATH:/opt/epics/bin I hope this configuration is not too deviant!
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
