I am sure the EPICS libraries are on my path. I have set the environment variables LD_LIBRARY_PATH and PATH from the very start. I would normally expect to see an architecture part to your library and command paths. So assuming the EPICS_HOST_ARCH environment variable is set, "$EPICS_BASE/lib" would instead be "$EPICS_BASE/lib/$EPICS_HOST_ARCH" and "$EPICS_BASE/bin" would instead be "$EPICS_BASE/bin/$EPICS_HOST_ARCH". -lewis The error message is the same:pvar_func_asSub../../bin/linux-arm/myexample: relocation error: ../../bin/linux-arm/myexample: undefined symbol:
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
