1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: Segment fault for edm 1-11-0s
To: "Sinclair, John William" <[email protected]>, Dirk Kraemer <[email protected]>, [email protected]
Cc: "Williams Jr, Ernest L." <[email protected]>
Date: Mon, 20 Nov 2006 17:20:24 -0500
I had the same problem on FC5 with kernel 2.6.18-1.2200FC5_SMP.
I tried edm 1-11-0m and 1-11-0p ...
They all behave same.
The debug info doesn't show much information:
> > > [pengs@dhcp-216-102 ~]$ gdb
> > > /ade/epics/supTop/extensions/R3.14.8.2/bin/linux-x86/edm
> > > GNU gdb Red Hat Linux (6.3.0.0-1.134.fc5rh) Copyright 2004 Free
> > > Software Foundation, Inc.
> > > GDB is free software, covered by the GNU General Public License,
> > > and you are welcome to change it and/or distribute copies of it under certain conditions.
> > > Type "show copying" to see the conditions.
> > > There is absolutely no warranty for GDB. Type "show warranty" for details.
> > > This GDB was configured as "i386-redhat-linux-gnu"...Using host libthread_db library "/lib/libthread_db.so.1".
> > > (gdb) run
> > > Starting program:
> > > Reading symbols from shared object read from target memory...done.
> > > Loaded system supplied DSO at 0x953000 [Thread debugging using
> > > libthread_db enabled] [New Thread -1208948512 (LWP 3633)] [New
> > > Thread -1209087072 (LWP 3662)] [New Thread -1208951904 (LWP 3661)]
> > > Program received signal SIG32, Real-time event 32.
> > > [Switching to Thread -1208951904 (LWP 3661)]
> > > 0x4932fa08 in clone () from /lib/libc.so.6
> > > (gdb) bt
> > > #0 0x4932fa08 in clone () from /lib/libc.so.6
> > > #1 0x003d0f00 in ?? ()
> > > #2 0x00000000 in ?? ()
> > > (gdb)
Strace shows the program gets into the problem everytime when it tries to load particular font.
So I installed all possible fonts. Then edm works fine for me now.
Help this would help.
Thanks.
Sheng
Re: Segment fault for edm 1-11-0s Dirk Kraemer
Re: Segment fault for edm 1-11-0s John William Sinclair
Prev: Re: Segment fault for edm 1-11-0s John William Sinclair
Next: Incorrect display of Y label of X-Y Graph in edm Jianguo DING
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: Segment fault for edm 1-11-0s Dirk Kraemer
