1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Segment fault for edm 1-11-0s
To: Dirk Kraemer <[email protected]>
Cc: [email protected]
Date: Mon, 20 Nov 2006 08:02:05 -0600
On Nov 20, 2006, at 5:50 AM, Dirk Kraemer wrote:
Hello all,
I have a problem with EDM. If I start EDM ,then
I see for a moment the message  "loading fonts" and a moment later
I get the message "segmentations fault".
I am running EDM on :
- Fedora 5 - gcc 4.1.0-3.i386
- Epics 3.14.8.2
- openMotif 2.3.0-0.1.9.i386
- edm 1-11-0s
I hope that someone can help me. It's the first time that I get this fault.
Regards
Dirk Kraemer
Sounds suspiciously like the problem I encountered on OS X. Here's a copy of the letter I sent to Jeff about this. Perhaps you're seeing the same sort of condition, but with some other pair of static constructors.
I downloaded and built the latest version of edm with the current R3.14.2 CVS branch of EPICS. Things build fine, but the executable suffers an access fault when run. I tracked the problem down to a race condition in the C++ static constructors. Code in EPICS_PV_Factory is invoking a guard class mutex that has yet to be set up.
Program received signal EXC_BAD_ACCESS, Could not access memory.
Reason: KERN_PROTECTION_FAILURE at address: 0x00000008
0x0008ae23 in epicsMutex::lock ()
(gdb) where
#0 0x0008ae23 in epicsMutex::lock ()
#1 0x00088e3a in ipAddrToAsciiEngine::allocate ()
#2 0x004aff0b in cac::cac ()
#3 0x004cfb5b in ca_client_context::ca_client_context ()
#4 0x004b25f4 in ca_context_create ()
#5 0x0041f4df in EPICS_PV_Factory::EPICS_PV_Factory ()
#6 0x0044cb2b in __static_initialization_and_destruction_0 ()
#7 0x8fe0fcb2 in __dyld__ZN16ImageLoaderMachO16doInitializationERKN11ImageLoader11LinkCon textE ()
#8 0x8fe0a1c6 in __dyld__ZN11ImageLoader23recursiveInitializationERKNS_11LinkContextE ()
#9 0x8fe0a164 in __dyld__ZN11ImageLoader23recursiveInitializationERKNS_11LinkContextE ()
#10 0x8fe0a164 in __dyld__ZN11ImageLoader23recursiveInitializationERKNS_11LinkContextE ()
#11 0x8fe0c646 in __dyld__ZN11ImageLoader15runInitializersERKNS_11LinkContextE ()
#12 0x8fe03070 in __dyld__ZN4dyld24initializeMainExecutableEv ()
#13 0x0000245a in _start ()
#14 0x000023c5 in start ()
The offending code in misc/ipAddrToAsciiAsynchronous.cpp is:
// for now its probably sufficent to allocate one
// DNS transaction thread for all codes sharing
// the same process that need DNS services but we
// leave our options open for the future
ipAddrToAsciiEngine & ipAddrToAsciiEngine::allocate ()
epicsGuard < epicsMutex > guard ( ipAddrToAsciiEnginePrivate::globalMutex );
if ( ! ipAddrToAsciiEnginePrivate::pEngine ) {
ipAddrToAsciiEnginePrivate::pEngine = new ipAddrToAsciiEnginePrivate ();
ipAddrToAsciiEnginePrivate::numberOfReferences++;
return * ipAddrToAsciiEnginePrivate::pEngine;
As a quick fix I just link libCom before the EDM libraries as well as after:
diff -ur /home/phoebus/NORUME/Desktop/edm/edmMain/Makefile /home/ phoebus/NORUME/
src/EPICS/extensions/src/edm/edmMain/Makefile
--- /home/phoebus/NORUME/Desktop/edm/edmMain/Makefile 2006-03-06 13:25:32.0000
00000 -0600
+++ /home/phoebus/NORUME/src/EPICS/extensions/src/edm/edmMain/ Makefile 2006-11-
14 13:12:30.000000000 -0600
@@ -10,7 +10,7 @@
edm_LIBS_Linux += 114135a4-6f6c-11d3-95bc-00104b8742df
edm_SYS_LIBS_Linux += Xm Xmu Xt Xp Xtst X11 pthread dl
-   edm_LIBS_Darwin += EdmBase cfcaa62e-8199-11d3-a77f-00104b8742df
+   edm_LIBS_Darwin += Com EdmBase cfcaa62e-8199-11d3-a77f-00104b8742df
    edm_LIBS_Darwin += 114135a4-6f6c-11d3-95bc-00104b8742df
    edm_SYS_LIBS_Darwin += Xm Xmu Xt Xp Xtst X11 pthread dl
I've sent mail to Jeff to see if he has a better fix, but for now I can at least work with EDM.
Eric Norum <[email protected]>
Advanced Photon Source
Argonne National Laboratory
(630) 252-4793
Re: Segment fault for edm 1-11-0s Dirk Kraemer
Prev: Segment fault for edm 1-11-0s Dirk Kraemer
Next: Re: Segment fault for edm 1-11-0s Dirk Kraemer
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
