1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: Naming conventions for devices and Epics records
To: "Kasemir, Kay" <[email protected]>, tech talk <[email protected]>
Date: Fri, 17 Nov 2006 11:55:02 -0500
Actually, 208t303 is a well-defined convention hereabouts for "208 to
303" (used in shared power supplies, I believe.)  Because "-" is not
allowed in our names.
> -----Original Message-----
> From: Kay-Uwe Kasemir [mailto:[email protected]]
> Sent: Friday, November 17, 2006 11:50 AM
> To: tech talk
> Subject: Re: Naming conventions for devices and Epics records
> Hello:
> It's Friday, so I can't help but add a few more comments.
> When you compare the link that Dave sent,
> > https://ics-web1.sns.ornl.gov/STANDARDS/Naming%20Conventions%
> > 20Instructional%20Document.pdf
> to the BESSY docs, you'll see things like underscores that are
allowed,
> but not required in some places.
> Earlier SNS naming documents contained phrases like "use upper/lower
> case
> and underscores however you like to improve readability".
> Good examples for a non-standard, resulting in long names, maybe
> readable,
> but definitely hard to parse. Worst are probably our instance numbers:
> "105" = 105th instance, or 5th instance on 1st system
> "05b" = 2nd instance on 5th system
> "_65kV" = the system that handles 65*10^3 Volts
>            - I think, because 65kV suggests a voltage.
>              For a name parser, it could also be the 65th instance
>              on the 'kV' system.
> "_FE65kV" = the system that handles 65*10^3 Volts on the front-end?
> "208t303" = no idea
Re: Naming conventions for devices and Epics records Kay-Uwe Kasemir
Prev: RE: Naming conventions for devices and Epics records Strong, William Herb
Next: RE: Naming conventions for devices and Epics records Allison, Stephanie
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Naming conventions for devices and Epics records Kay-Uwe Kasemir
Next: RE: Naming conventions for devices and Epics records Strong, William Herb
