1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Naming conventions for devices and Epics records
To: Lecorche Eric <[email protected]>
Date: Fri, 17 Nov 2006 17:04:49 +0100
Well - that was easy. Here's the BESSY part about signal naming. We just started to enforce rules on signal names after some years of experience with everything after the colon being free-style.
So - no experience with these signal naming rules. Yet.
Ralph
Ralph Lange wrote:
You can see the BESSY Device naming conventions in the "Concepts" part on
http://www-csr.bessy.de/control/Docs/
(which should be visible from the outside - the APS page Pete was mentioning is not)
We also have a convention for signal names (everything after the first colon) - but that is only available from within BESSY. Maybe I can save and mail it to you.
Ralph
Title: SignalNamingConv < Controls < TWiki
r11 - 10 Nov 2006 - 08:04:14 - IngoMuellerYou are here: TWiki >  Controls Web  > SignalNamingConv
Convention for Signal Names
Starting with the preparations for the MLS control system (Willy-Wien-Lab) we have agreed on a soft convention about signal names, i.e. the part of EPICS record names that follow the last colon. The naming convention for the first part of a record name (Device Name) is described in BESSY's Device Naming Convention document.
The status of this convention is a strong suggestion. Creating signal names that do not follow these rules has to be well-justified (and the reasons documented).
Signal Names will have multiple parts. This convention will give guidelines for the first parts of a signal name, defining the follwing (end) part of the name will always be left freely to the database designer.
General Style Rules
Separation between parts of the Signal Name should be done by using upper case characters in the middle of the name. Do not use underscores ("_") or dashes ("-") to separate name parts. For the first name parts under this convention upper case separation is mandatory, for the free part it is strongly advised.
For some signals (e.g. single bit status channels) the second part (Signal Item) is not mandatory. Nevertheless - in all cases the database designer should use both defined parts if possible, as this makes name parsing, finding channels in the archiver, and similar tasks much easier.
First Part: Signal Type
The Signal Type specifies the type of signal in terms of function, direction of data flow, and value type (analog/digital). The first table contains types for channels that are part of a devices' public interface, the second table applies to channels that are internal to complex databases.
Public Channels
Tag Name Attributes
set set point analog, to device
rdbk readback analog, from device
cmd command command executed by device, to device
sel mode select select one-of-many mode, to device
stat status binary (single or one-of-many), from device
Private Channels
Tag Name Attributes
var variable passive record to just store stuff
mbox mailbox similar
buf buffer similar, for arrays
calc calculation calculation of values
cnt counter counting time or events
fwd forward forward values between records
sel select select a mode or position
in input raw value, from device
out output raw value, to device
raw raw value raw value, bidirectional
bits bitfield raw value, multibit (mbbiDirect, mbboDirect)
map mapping bit mapping
Second Part: Signal Item
The Signal Item specifies the kind of item or value that the signal consists of. While the Signal Type describes the signal in term of control system features, the Signal Item gives a hint to the physical (or physicist) meaning of the value. The first table contains Signal Items for digital signals, while the second table is meant to describe analog kinds.
Digital Channels
Tag Name Attributes
Pwr   device mains power
Access   access mode (local/remote)
Reset   reset command
Trig Trigger triggered devices
Gate   gated devices
Switch Switch read a hardware switch
Door   door status
Ilock Interlock interlock signal
Relay   relay state
Watchdog   watchdog status
Detect   detector status
One-of-Many Signals
Outp Output output selector
Pos Position position selector
Runmode   run mode
Single "Error" Bits
Over   exceeding an upper limit
Under   exceeding a lower limit
Range   out of range
Tol Tolerance out of tolerance
Valid Validity signal is valid
Ground   ground fault
Fail Failure failure
Break Circuit Breaker circuit breaker status
Leak Leak Detector leak detector status
Replace   notification to replace something
Analog Channels
Tag Name Attributes
Angle   angular sensors
Curr Current all kinds of electrical currents
Ampl Amplitude signal amplitude
Field   magnetic and electric field strength
Flow   mechnical currents: air or water flow
Freq Frequency generators
Delay   pulse delay
Width   pulse width
Gap   undulators
Level   all kinds of levels and thresholds
Press Pressure pressure sensors
Shift   undulators
Temp Temperature temperature sensors
Time   time (absolute and relative)
Timeout   timeout
Count   counter value
Volt Voltage electrical voltage
Power   electrical Power
Strings
Tag Name Attributes
Str String
Examples
Just some examples to give an idea of the intentions...
Name Description
cmdPowerOff command to switch device OFF
cmdPowerStandby command to switch device STANDBY
cmdPowerOn command to switch device ON
selRunMode select run mode
statRunMode run mode status
statReplaceBottle "Replace Bottle" indicator
calcCmdWord0 internal calc to combine command bits
outCmdWord0 output rec connected to HW that writes the command word
inStatWord2 input rec connected to HW for status word
statPower power status: ON/STANDBY/OFF
setVolt ps: voltage setpoint
rdbkVolt ps: voltage readback
rdbkCurr ps: current readback
rdbkTemp01 temperature readback
rdbkTemp02 dito
setLevelOverflowAlarm sets the threshold for signalling overflow
setTimeout sets a timeout (start) value
cntTimeout timeout counter
varSelectionMask selection mask buffer (seq.SELL points to this)
Additions
This convention is not fixed nor finished!
If you find you have to name a channel and you don't see a way to generate a name with the existing tags, feel free to suggest extensions to these tables. We should discuss suggestions at one of the regular group meetings and collaborate to make these naming conventions work for everyone.
-- RalphLange - 13 Apr 2006
Edit | WYSIWYG | Attach | Printable | Raw View | Backlinks: Web, All Webs | History: r11 < r10 < r9 < r8 < r7 | More topic actions
Powered by TWiki
This site is powered by the TWiki collaboration platformCopyright © by the contributing authors. All material on this collaboration platform is the property of the contributing authors.
Ideas, requests, problems regarding TWiki? Send feedback
Naming conventions for devices and Epics records Lecorche Eric
Re: Naming conventions for devices and Epics records Ralph Lange
Prev: Re: Naming conventions for devices and Epics records Pete Jemian
Next: Re: Naming conventions for devices and Epics records Pete Jemian
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Naming conventions for devices and Epics records Ralph Lange
Next: Re: Naming conventions for devices and Epics records Luedeke Andreas
