1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Naming conventions for devices and Epics records
To: tech talk <[email protected]>
Date: Fri, 17 Nov 2006 10:24:53 -0500
On Nov 17, 2006, at 09:49 , Lecorche Eric wrote:
As we are starting our new Spiral2 project, I am now gathering some pieces of information in order to establish naming conventions both for devices and Epics records and taking into account habits inherited from the existing Ganil installation.
I already got a document from Diamond describing such naming conventions but I would be interested by having others coming from other labs.
Can some labs send me some documents relevant for this topic ?
Hello Eric:
Whatever you do, write your naming standard
like a computer language definition, for example using BNF:
<name> ::= <system> ":" <device> ":" <signal>
<system> ::= <system-id> <system-instance> "-" <subsystem-id> <subsystem-instance>
<system-instance> ::= "" | "_" <instance>
<instance> ::= <integer> | <integer> <a-to-z>
An additional, verbose, more human readable explanation is nice,
but allow no misconception about the use of upper/lower case, '_' or ':',
or the structure of instance numbers.
This asserts that you get parsable names, which you'll need
for name-related tools. Actually, try to write a name parser right away,
for example in perl, to
a) check if your naming standard allows parsing
b) have such a tool to check names as soon as the first person tries
   to define the first process variable.
That way, you might avoid ending up with names like DTL_Xyz:Gadget105:Value, wondering:
Is this the 105th gadget of the overall drift tube linac, or the 5th gadget on DTL #1?
How do I write a regular expression that gives me all the devices on DTL #2?
-Kay
RE: Naming conventions for devices and Epics records Purcell, J. David
Naming conventions for devices and Epics records Lecorche Eric
Prev: Naming conventions for devices and Epics records Lecorche Eric
Next: Re: Naming conventions for devices and Epics records Pete Jemian
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: RE: Naming conventions for devices and Epics records Purcell, J. David
