1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Scaling Database entries
To: Dirk Zimoch <[email protected]>
Cc: [email protected]
Date: Thu, 16 Nov 2006 10:10:34 -0600
Hi Dirk,
Dirk Zimoch wrote:
In 3.13, there was no "SLOPE", and even now I cannot find any 3.14 Record Reference Manual which would explain the use of "SLOPE". StreamDevice does not make a difference between "SLOPE" and "LINEAR" at the moment.
True, SLOPE conversion was added in R3.14. It is described in the Base Release Notes, but it should be documented elsewhere too. Unfortunately the Record Reference Manual is so out of date that it's embarrasing, but APS does not have the manpower to update it, and only one person has volunteered to help work on the Wiki version (which is still only for R3.13). I will make sure it's listed in appropriate places in the Application Developers Guide for R3.14.9 though.
StreamDevice should have some way for the author of a protocol file to specify what the device's raw range actually is for analog records, and it should perform the calculation of ESLO and EOFF from that raw range and the EGUL+EGUF pair.
I think, I will add that. This can easily be done with two variables in the protocol file.
Great. The axRecord.c files already set EOFF to EGUL for you, so the code in your special_linconv() routines only needs to do something like this, assuming that the raw data values range from 0 to rawRange:
    if (after && prec->linr == menuConvertLINEAR) {
        prec->eslo = (prec->eguf - prec->egul) / rawRange;
- Andrew
There is considerable overlap between the intelligence of the smartest
bears and the dumbest tourists -- Yosemite National Park Ranger
RE: Scaling Database entries David Dudley
Re: Scaling Database entries Dirk Zimoch
Re: Scaling Database entries Andrew Johnson
Prev: Re: Scaling Database entries Dirk Zimoch
Next: Re: Motion control failure at APS Ronald L. Sluiter
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: Modbus driver David Dudley
