Hi Andrew
Andrew Johnson wrote:
Dirk Zimoch wrote:
if you driver does not set ESLO and EOFF, you can set it in your db.
Calculate manually what to set. I did the same with StreamDevice.
Don't forget to set LINR to "LINEAR", of course.
If you want to set ESLO and EOFF yourself, you should set LINR to
"SLOPE" rather than "LINEAR" or there's a danger the device support will
overwrite your values if someone modifies any of the conversion fields.
StreamDevice might not do so if it doesn't have a special_linconv
routine, but then it's not following the full ai/ao standard. Most
analog device supports will overwrite ESLO and EOFF; by relying on non-
standard behaviour you're making it harder for someone to replace
hardware using a StreamDevice interface with some other device, because
they now have to change more than just the DTYP and INP/OUT field of
their database records when they move (and they might not realize that).
In 3.13, there was no "SLOPE", and even now I cannot find any 3.14
Record Reference Manual which would explain the use of "SLOPE".
StreamDevice does not make a difference between "SLOPE" and "LINEAR" at
the moment.
StreamDevice should have some way for the author of a protocol file to
specify what the device's raw range actually is for analog records, and
it should perform the calculation of ESLO and EOFF from that raw range
and the EGUL+EGUF pair.
I think, I will add that. This can easily be done with two variables in
the protocol file.
The other option you might want to support if
you don't already would be to control whether any conversions get done
at all - many instruments return engineering units anyway, and that's
why the analog records allow the device layer to set the VAL field
directly and return 2. This is used a lot for GPIB instrumentation.
That's what I do. If a floating point format is used with ai or ao, the
device support uses the VAL field. See the StreamDevice documentation
for each record type.
Dirk
Dr. Dirk Zimoch
Swiss Light Source
Computing and Controls
Paul Scherrer Institut
phone +41 56 310 5182
fax +41 56 310 4413
- Re: Scaling Database entries Andrew Johnson
- RE: Scaling Database entries David Dudley
- Re: Scaling Database entries Dirk Zimoch
the body. No never should Khayman smile as he of Rodney Sullivan
<2006>
<2006>
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
