1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Irmis applicative points
To: [email protected]
Date: Wed, 15 Nov 2006 11:38:15 +0100
Some various points concerning the use of Irmis :
- When I run several times the pv-crawler with --force option, it adds new lines into the ioc_boot table so that when searching through the idt:pv within the history mode, the same boot date appears several times although I think that it should appear only once. Am I right and, if so, is there a way to avoid that ?
- If I move one PV from one IOC to another one, having done that the PV info is ok but the boot history still lists the history for both the IOCs where the PV is currently assigned (that's right) and also the one where the PV was previously installed. I don't think this is correct ?
- The pv-crawler does not detect if one PV is used in several IOCs. Although I could have a small SQL script detecting these mistakes, is there an other way to avoid that ?
- Did someone wrote a crawler for EDM clients (not MEDM). I suspect (not having yet watch at this point) that it should be different from the adl crawler from the Irmis package ?
Eric Lecorche
begin:vcard
fn;quoted-printable:Eric L=C3=A9corch=C3=A9
n;quoted-printable:L=C3=A9corch=C3=A9;Eric
org:Ganil;Groupe Informatique Machine
adr:;;BP 55027;Caen;;14076;France
email;internet:[email protected]
title:DBA / resp. GMAO / CC Ganil
tel;work:02 31 45 47 35
tel;fax:02 31 45 47 28
url:http://www.ganil.fr
version:2.1
end:vcard
Re: Irmis applicative points Andrew Johnson
Prev: Re: devSNMP: Thread error? Bertrand H.J. Biritz
Next: Re: Irmis applicative points Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Modbus driver David Dudley
