Kurt: We had the same problem at BioCARS (APS) and fixed it in the same
way. It's a cheap fix, it works - and that's what really matters.
-Reinhard.
-----Original Message-----
Sent: Monday, November 13, 2006 4:56 PM
To: Mark Rivers
Cc: Ronald L. Sluiter; Emmanuel Mayssat; EPICS;
[email protected]
Subject: Re: Motion control failure at APS
The only times we've had spurious limit switch problems that the
transition
board capacitors didn't solve were due to exceptionally noisy
chopper-type
microstepper drivers. For this I designed a custom socket for the OMS
VME58
limit switch pals that puts caps right on the limit switch sense pins.
Not pretty
but it works.
Kurt
Mark Rivers wrote:
> The transition cards that the APS BCDA group built to connect the
> OMS58/MAXv and the ACS Step-Pak drivers have on-board de-glitching
> capacitors. These increase the time constant on the limit switch
lines
> so that we never see problems, even with very long lines from the
> controller to the driver.
> This is generally a simple and cheap solution.
> Mark
>> From: Ronald L. Sluiter [mailto:[email protected]]
>> Sent: Monday, November 13, 2006 2:15 PM
>> To: Emmanuel Mayssat
>> Cc: EPICS
>> The OMS VME58 is susceptible to noise on the limit switch lines.
>> This has been the most frequent problem that I have been called on
>> the diagnose.
>> Kurt Goetze and I did some testing to see if this is a
>> problem with the
>> MAXv. Of course we can't quantify it, but it appears that OMS has
>> done a much better job with the MAXv on this issue.
>> Ron
>> Emmanuel Mayssat wrote:
>>> I actually had the exact opposite problem.
>>> My motor controller would barely start a move.
>>> The limit switches were reported as not closed, and the
>> apparatus was in
>>> a safe position to operate. The problem was due to glitches
>> on the limit
>>> switch cables (we actually never observed those glitches).
>> The problem
>>> was reproducible in a controlled environment (engineering bench).
>>> As of today, we think it was due to cable length and cross talking.
>>> We rebuild and shortened the cables. It immediately worked.
>>> Food for thoughts and... time for lunch,
>>> Emmanuel
>>> On Mon, 2006-11-13 at 12:56 -0600, Mark Rivers wrote:
>>>> Folks,
>>>> We have seen failures in the past where a motor moved
>> constantly at a
>>>> slow rate right past limit switches on an OMS58. It
>> happened only on a
>>>> single axis, not on all 8 axes.
Re: Motion control failure at APS Kurt Goetze
Scaling Database entries David Dudley
<2006>
Re: Motion control failure at APS Bill Nolan
Re: Motion control failure at APS Ronald L. Sluiter
<2006>
