1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: ant problem when building Irmis
To: Claude Saunders <[email protected]>
Cc: [email protected]
Date: Fri, 10 Nov 2006 11:56:27 +0100
Hi Claude,
Some pretty good news, although it is true that everything is not clear ...
After having checked once again the whole Java installation, everything seemed to be ok and I still got the problem ... As a last chance, one Java programmer who was passing there at the moment adviced me to try to use netBeans to perform the compilation ... and doing like that, it worked fine (the only thing I have to do was to modify the CableWindow.java and ComponentWindow.java files by replacing the java variable "enum" by "enum2" as "enum" is a reserved word in JDK 1.5).
So lastly, it works (but I don't know why not previously !) and I am able now to run the Irmis desktop : idt::ioc and idt::admin run ok, when I try to launch idt::component or idt::cable, I get an error (Exception : "Unable to find root of housing hierarchy") but I don't mind as I don't need these functionalities . My main objective is to run idt::pv on a filled database so I have now to adapt the crawlers to our environment and that's what I am going to try now, even not having any experience with perl ...
Thanks for your help !
Eric
begin:vcard
fn;quoted-printable:Eric L=C3=A9corch=C3=A9
n;quoted-printable:L=C3=A9corch=C3=A9;Eric
org:Ganil;Groupe Informatique Machine
adr:;;BP 55027;Caen;;14076;France
email;internet:[email protected]
title:DBA / resp. GMAO / CC Ganil
tel;work:02 31 45 47 35
tel;fax:02 31 45 47 28
url:http://www.ganil.fr
version:2.1
end:vcard
ant problem when building Irmis Lecorche Eric
Re: ant problem when building Irmis Claude Saunders
Re: ant problem when building Irmis Lecorche Eric
Prev: Re: Support for larger messages in IOC Error Logging facility Andrew Johnson
Next: Siemen's PLC Interfaces Dalesio, Leo `Bob`
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: ant problem when building Irmis Claude Saunders
Next: AAI/AAO database information David Dudley
