1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: HP8116A signal generator
To: Eric Norum <[email protected]>
Cc: TECHTALK tech-talk <[email protected]>
Date: Fri, 03 Nov 2006 10:41:29 -0800
Eric.
Some time ago I wrote [basic, i.e., supporting basic features]
devsup for a Hp8664 generator. Some HP generators use
a fairly compatible command set AFAIK. Maybe this applies
to the 8116 (I know that it works for the 8644) ?
HTH
-- Till
Eric Norum wrote:
All my memories of GPIB horrors are returning.
I've put together ASYN/devGPIB support for an (obsolete) HP8116A signal generator. I'm trying to communicate with the generator through an Agilent E5810A GPIB/LAN adapter. As far as I can tell I'm sending the correct strings but the generator never acts upon the commands. Every once in a very long while it will return a status message in response to a command, but most of the time it just sits there. Once in a while it sets the SRQ line and then leaves it set forever.
Does anyone out there have experience with HP8116A GPIB communication?
HP8116A signal generator Eric Norum
Re: HP8116A signal generator David Maden
Prev: Database hanging Rees, NP (Nick)
Next: Re: Database hanging Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: HP8116A signal generator Kate Feng
Next: Enum labels via JCA? Christopher Larrieu
