1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Support for larger messages in IOC Error Logging facility
To: "J. Lewis Muir" <[email protected]>
Cc: [email protected]
Date: Wed, 01 Nov 2006 13:36:49 -0600
J. Lewis Muir wrote:
I have a situation where I would like to log messages via the IOC Error Logging facility (e.g. errlogPrintf) that are longer than the current maximum message size of 256 characters (as of EPICS 3.14.8.2).
I see that I probably could change MAX_MESSAGE_SIZE in EPICS base at
src/libCom/error/errlog.c
but I'd rather not be running a modified EPICS base.
As a work around, I could break up the longer messages into smaller pieces, logging each piece individually, but I would rather not. Is there a better way to handle this?
I don't see any obvious reason why we can't make MAX_MESSAGE_SIZE an initialization parameter and add a 2-argument init routine to allow it to be set.
Or if I submitted a patch to allow a larger message size perhaps by changing the errlogInit function to allow a second argument of "int msgsize", would it likely be accepted or are there reasons against this?
If you would like to test out the attached (untested) patch and let me know if it solves the issue, I'll see that it gets into R3.14.9.
To increase the message size, call errlogInit2(0, maxMsgSize) before something else calls errlogInit(0).
- Andrew
There is considerable overlap between the intelligence of the smartest
bears and the dumbest tourists -- Yosemite National Park Ranger
Index: errlog.c
RCS file: /net/phoebus/epicsmgr/cvsroot/epics/base/src/libCom/error/errlog.c,v
retrieving revision 1.35.2.16
diff -u -b -r1.35.2.16 errlog.c
--- errlog.c	22 Mar 2005 21:48:43 -0000	1.35.2.16
+++ errlog.c	1 Nov 2006 19:32:27 -0000
@@ -86,6 +86,7 @@
     msgNode      *pnextSend;
     int	         errlogInitFailed;
     int	         buffersize;
+    int	         maxMsgSize;
     int	         sevToLog;
     int	         toConsole;
     int	         missedMessages;
@@ -152,7 +153,7 @@
     isOkToBlock = epicsThreadIsOkToBlock();
     pbuffer = msgbufGetFree(isOkToBlock);
     if(!pbuffer) return(0);
-    nchar = tvsnPrint(pbuffer,MAX_MESSAGE_SIZE,pFormat?pFormat:"",pvar);
+    nchar = tvsnPrint(pbuffer,pvtData.maxMsgSize,pFormat?pFormat:"",pvar);
     msgbufSetSize(nchar);
     return nchar;
@@ -195,7 +196,7 @@
     if(pvtData.atExit) return 0;
     pbuffer = msgbufGetFree(1);
     return nchar;
@@ -248,7 +249,7 @@
     if(!pnext) return(0);
     nchar = sprintf(pnext,"sevr=%s ",errlogGetSevEnumString(severity));
     pnext += nchar; totalChar += nchar;
-    nchar = tvsnPrint(pnext,MAX_MESSAGE_SIZE-totalChar-1,pFormat,pvar);
+    nchar = tvsnPrint(pnext,pvtData.maxMsgSize-totalChar-1,pFormat,pvar);
     if(pnext[-1] != '\n') {
         strcpy(pnext,"\n");
@@ -366,7 +367,7 @@
     va_start (pvar, pformat);
-    nchar = tvsnPrint(pnext,MAX_MESSAGE_SIZE,pformat,pvar);
+    nchar = tvsnPrint(pnext,pvtData.maxMsgSize,pformat,pvar);
     va_end (pvar);
     if(nchar>0) {
         pnext += nchar;
@@ -386,15 +387,20 @@
     return;
+struct initArgs {
+    int bufsize;
+    int maxMsgSize;
 LOCAL void errlogInitPvt(void *arg)
-    int bufsize = *(int *)arg;
+    struct initArgs *pconfig = (struct initArgs *) arg;
     void	*pbuffer;
     epicsThreadId tid;
     pvtData.errlogInitFailed = TRUE;
-    if(bufsize<BUFFER_SIZE) bufsize = BUFFER_SIZE;
-    pvtData.buffersize = bufsize;
+    pvtData.buffersize = pconfig->bufsize;
+    pvtData.maxMsgSize = pconfig->maxMsgSize;
     ellInit(&pvtData.listenerList);
     ellInit(&pvtData.msgQueue);
     pvtData.toConsole = TRUE;
@@ -428,17 +434,26 @@
     /*Note that exitHandler must destroy waitForExit*/
-epicsShareFunc int epicsShareAPI errlogInit(int bufsize)
+epicsShareFunc int epicsShareAPI errlogInit2(int bufsize, int maxMsgSize)
     static epicsThreadOnceId errlogOnceFlag=EPICS_THREAD_ONCE_INIT;
+    struct initArgs config;
-    epicsThreadOnce(&errlogOnceFlag,errlogInitPvt,(void *)&bufsize);
+    if (bufsize < BUFFER_SIZE) bufsize = BUFFER_SIZE;
+    config.bufsize = bufsize;
+    if (maxMsgSize < MAX_MESSAGE_SIZE) maxMsgSize = MAX_MESSAGE_SIZE;
+    config.maxMsgSize = maxMsgSize;
+    epicsThreadOnce(&errlogOnceFlag, errlogInitPvt, (void *)&config);
     if(pvtData.errlogInitFailed) {
         fprintf(stderr,"errlogInit failed\n");
         exit(1);
     return(0);
+epicsShareFunc int epicsShareAPI errlogInit(int bufsize)
+    return errlogInit2(bufsize, MAX_MESSAGE_SIZE);
 epicsShareFunc void epicsShareAPI errlogFlush(void)
     int count;
@@ -504,7 +519,7 @@
         msgNode	*plast;
 	plast = (msgNode *)ellLast(&pvtData.msgQueue);
-	needed = MAX_MESSAGE_SIZE + sizeof(msgNode) + MAX_ALIGNMENT;
+	needed = pvtData.maxMsgSize + sizeof(msgNode) + MAX_ALIGNMENT;
 	remaining = pvtData.buffersize
 	    - ((plast->message - pbuffer) + plast->length);
 	if(needed < remaining) {
Re: Support for larger messages in IOC Error Logging facility J. Lewis Muir
Prev: Re: calcout without update Tim Mooney
Next: HP8116A signal generator Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Support for larger messages in IOC Error Logging facility J. Lewis Muir
Next: Re: Support for larger messages in IOC Error Logging facility J. Lewis Muir
