I have a situation where I would like to log messages via the IOC Error
Logging facility (e.g. errlogPrintf) that are longer than the current
maximum message size of 256 characters (as of EPICS 3.14.8.2).
I see that I probably could change MAX_MESSAGE_SIZE in EPICS base at
src/libCom/error/errlog.c
but I'd rather not be running a modified EPICS base.
As a work around, I could break up the longer messages into smaller
pieces, logging each piece individually, but I would rather not. Is
there a better way to handle this?
Or if I submitted a patch to allow a larger message size perhaps by
changing the errlogInit function to allow a second argument of "int
msgsize", would it likely be accepted or are there reasons against this?
J. Lewis Muir
- Re: Support for larger messages in IOC Error Logging facility Andrew Johnson
RE: Get new, improved Matlab CA support, and crash your IOC with put callbacks Jeff Hill
calcout without update Emmanuel Mayssat
<2006>
<2006>
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
